Go to Post There are zillions more volunteers than paid staff. We are FIRST. - Rick TYler [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 01:02
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Y-cables and switches
Posted by EJ at 2/18/2001 1:46 PM EST
Student on team #254, Cheesy Poofs, from Bellarmine.
Can ne 1 tell me y when a joystick and a switch are connected to the y-cable, which is connected to port 1, that when the joystick (that is connected to the y-cable) is on full forward and the a joystick (connected to port 2) is on full reverse that the switch looses voltage? if u have ne advice to offer it would be greatly appreciated
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Y-cables and switches
Posted by Nate Smith at 2/18/2001 3:13 PM EST
Other on team #66, Frostbite, from Willow Run High School and GM Powertrain.
In Reply to: Y-cables and switches
Posted by EJ on 2/18/2001 1:46 PM EST:
: Can ne 1 tell me y when a joystick and a switch are connected to the y-cable, which is connected to port 1, that when the joystick (that is connected to the y-cable) is on full forward and the a joystick (connected to port 2) is on full reverse that the switch looses voltage? if u have ne advice to offer it would be greatly appreciated
Just out of curiosity, which digital input on the OI do you have the switch(connected to the Y-cable) hooked to? Looking over the control system manual, I don't see anything that should interfere between ports 1 and 2, but just to be safe, do you have an open pin on ports 3 or 4 you could hook the switch to? That might help...
Nate
[IMG] code is Off
maximum length of joystick cables archiver 2001 2 23-06-2002 23:54
