Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 14-03-2014, 10:27
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Maintenance mode TeleOp
Hey guys! I figured a new idea would be a refreshing change against all the question threads, so I wanna share something that our team realized. Its a cool little trick for keeping shop code and competition code different!
Up until now, whenever we wanted to test something electronically, we would have to create a new project and just instantiate a single motor or sensor or whatever to make absolutely sure nothing else interfered. However, what we realized is that in the main project you use, in the teleOp branch have a simple couple lines of code:
Code:
(operatorControl())
	if(DriverStation->GetDigitalIn(8))
		//Competition code, lots of automation, proper button mappings,
		//etc.,
	else
		//Shop code, simple button assignments, zero automation,
		//rewritten whenever you need to test something, "whiteboard"
		//code.
This way, so long as you make sure you don't use Digital Input 8 for anything else, you can easily test an isolated motor or sensor or whatever, while keeping your same project. Does anyone else use small tricks like this, or improved versions of this?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 14-03-2014, 12:08
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Maintenance mode TeleOp
Have you tried using Test mode? http://wpilib.screenstepslive.com/s/...sing-test-mode
Unread 14-03-2014, 12:30
AKA: Michael Shires
FRC #0384 (Sparky)
No actually I hadn't... I'd always seen it but had no idea what it did, and didn't want something to happen I wasn't expecting. So its just another teleOp code section, to keep your comp code and shop code seperate? Cause that sounds genius and is a whole lot less ghetto than what we're doing.
Unread 14-03-2014, 12:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Test mode is explicitly not connected with Teleop. It's another mode in addition to Autonomous and Teleoperated. The idea is to give you direct access via the Dashboard to each individual sensor and actuator on the robot.
Unread 15-03-2014, 09:29
AKA: Michael Shires
FRC #0384 (Sparky)
Interesting. I noticed that it doesn't default to having a while loop in it in the simple robot template. Is test mode supposed to just be a run through of every thing, or have some semblance of input control?
Unread 15-03-2014, 12:38
Rookie Year: 1997
In the simple robot template, teleop doesn't have a while loop by default either. Make of that what you will.
