Go to Post We can build it... we have the technology...better than it was before... Better...stronger...faster.... more PINK - Barry Bonzack [more]
Unread 14-03-2014, 23:31
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Week3 cumulative Twitter stats & OPRs
Stats and OPRs based on Twitter Qual match data as of Fri 3-14-2014 22:30:53 ET.
The usual Twitter data caveats apply.
NOTE: LOOK FOR UPDATED DATA TO BE POSTED LATER IN THIS THREAD
Unread 14-03-2014, 23:53
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Rookie Year: 1997
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Re: Week3 cumulative Twitter stats & OPRs
Excerpt from the above post:
win foul points awarded:
20 average (mean)
220 max
lose foul points awarded:
5 average (mean)
110 max
The above is a very simple assessment of how the foul points affect this game. 4X as many foul points to the winning alliance....this means that fouls swing a large percentage of matches.
50 point foul is effectively a automatic loss most of the time.
Tragic.
Worst game design since 2003, yet no real action to correct....
Tragic.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 14-03-2014, 23:58
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
20 foul points on average for the winning alliance. That is insane. What makes it worse, is that by the look at average scores, they are not a ton different then last year, but the fouls are worth a ton more. I think the game designers expected higher average match scores to make up for higher foul scores.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 15-03-2014, 09:28
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
20 average (mean)
220 max
5 average (mean)
110 max
Tragic.
Tragic.
Agreed that the impact of foul points is tragic... and that foul points swinging the outcome of the match is likely a significant contributor to this statistic; however, I do think there is another possible/probable cause.
Fouls "take advantage" of less experienced, lower-performing teams. The teams that are more likely to get careless HP fouls, struggle to pickup a ball when inbounding, play hard defense that involves a manipulator flipping out and getting inside an offensive bot, or pin for too long are the teams that are less familiar with the rules, haven't kept up with the Q&A, and haven't designed as effective an offensive bot.
The fact that the teams most likely to suffer from the heavy fouls are also the teams that FIRST is having the hardest time retaining isn't a good thing for FIRST growing at or above average next year.
Consider me more and more on the side of "bring foul values down to 10 and 30." Keep in mind this is still 333% and 150% the value of fouls in 2013.
Big, Bad, Bobth Post! (#319)
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 15-03-2014, 11:25
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
20 average (mean)
220 max
5 average (mean)
110 max
Tragic.
Tragic.
Agreed. Quite sad to see some really good strategies play out and then that one tech foul swings it the other way.
I think a 30 point value should be the max assigned to the tech foul. Hopefully, based on average win/loss margins it will have a smaller swing effect on match outcomes.
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 15-03-2014, 20:34
Ether's Avatar
Rookie Year: 1969
Twitter Qual Match Stats
based on Twitter Qual match data as of Sat 15 Mar 2014 20:13:09 ET.
I've removed the Quartile data from the stats report. In their place I will be posting histograms later this evening. Also Twitter-based OPRs. So check back later.
Unread 15-03-2014, 21:01
Ether's Avatar
Rookie Year: 1969
Unpenalized Winning Margin Histogram
Name:	unpenalized win margin.png
Unread 15-03-2014, 21:37
Ether's Avatar
Rookie Year: 1969
OPR for Final, Foul, Auto, & TeleOp
based on Twitter Qual match data as of Sat 15 Mar 2014 20:56:33 ET.
Data is shown for teams which have played at least 6 matches.
File Type: xls OPR (from Twitter data 3-15-2014 205633).xls (369.0 KB, 303 views)
Unread 16-03-2014, 09:15
billylo's Avatar
billylo billylo is offline
FRC #0610 (Coyotes)
Rookie Year: 2012
billylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant future
Thumbs up Re: Week3 cumulative Twitter stats & OPRs
Very well presented, your picture is worth a thousand words! Would you mind if I combine your charts with my questionnaire results for submission to FIRST tomorrow?
The questionnaire can be found here.
[would it be possible to calculate the percentage of games finished within +/- 50 points? i.e. a tech foul call or non-call would have swung the results of that game?]
Unread 16-03-2014, 09:23
billylo's Avatar
FRC #0610 (Coyotes)
Rookie Year: 2012
^^^ This says it all. Thank you Nathan. ^^^
Unread 16-03-2014, 11:02
Ether's Avatar
Rookie Year: 1969
You have my permission.
See attached chart. Of the 3022 non-tied qual matches in the Twitter data dated 3/15/2014 20:13:09 ET, there were 1619 matches with final score (including awarded foul points) margin less than or equal to 50.
Name:	win margin cumulative.png
Unread 16-03-2014, 12:39
Ether's Avatar
Rookie Year: 1969
Alliance Score Residuals
Example graph interpretation:
81 - 18 = 62% of Alliance Unpenalized Scores were within +/- 20 points of the "OPR" predicted value.
66 - 32 = 35% of Alliance Unpenalized Scores were within +/- 10 points of the "OPR" predicted value.
Name:	Alliance unpenalized scores L2 norm residuals.png
Unread 16-03-2014, 13:01
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Tragic.
Tragic.
This can be a double whammy for District teams on the cusp of making it to the District Championship. The points for winning qualifying matches can function as the tie-breaker for determining who makes the cut-off and who doesn't. Your team can do everything right, but if a partner makes a mistake or doesn't know the rule, there goes 2 points. (And vice versa, you can do everything wrong and still get 2 points!) We do not have the manpower or experience to pull a 51 and record every foul and coach other teams through their problem areas. At our next event we will make a point to bring it up before every match so everyone knows.
At the end of the season I would be curious to see how many teams make or do not make the DCMP by foul points.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 16-03-2014, 15:35
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I agree that would be an interesting metric, although the match data doesn't show how deserving the fouls were or how consistently they were called.
As you are probably aware the twitter data (caveats apply) shows 1778 lost one match and won another at Mt Vernon due to fouls, so no net impact.
  #15   Spotlight this post!
Unread 16-03-2014, 15:46
Best Available Data
Yep, and that make me wonder if they are uniformly enough distributed so that it is a net zero effect. I think the safest thing to do is assume that they are deserved. At Mr. Vernon I thought the refs did a great job.
