Go to Post You earn what you work for. - Akash Rastogi [more]
  #16   Spotlight this post!
Unread 17-03-2014, 06:24
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: High Traction Wheels
Originally Posted by cbale2000 View Post
(We've used the McMaster Blue Nitrile that Andrew suggested above, but found cutting it to the correct size can be a pain).
MOE is using this this year and we found a band saw cuts it with ease. Just buy 1 linear foot of the 1 foot wide sheets (if using 4 inch wheels wider options available for larger wheels) set up a guide the width of the wheel away from the bade, and push it through tread down. This gets you 11-12 1 inch wide wheels worth depending on how well you spaced your guide.
Also, I'll throw in a vote for Colsons and AM Performance with Blue Nitrile, used both, like both, sorry, no concrete data. Just make sure you use all 6 bolt holes we sheared off a wheel that had only 3 bolts the other day
I was wondering if anyone has used Banebots new "ground flat Colsons" and seen how they compare to regular Colsons.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
