Go to Post You can't stop trying to look for other ways to do things, or that really defeats the whole purpose of inovation. - AmoryG [more]
Unread 17-03-2014, 09:24
miniscil miniscil is offline
FRC #4050
miniscil is an unknown quantity at this point
Autonomous Mode - only one side operates (Labview)
We trying to get autonomous drive working and having issue with getting both sides of drive train to respond. Only one side will operate.
The drive train operates fine in teleop.
We setup using in Labview as Robot Project (arcade drive).
We have tested on our last years robot and had the same issue occur. We tried from several computers to build and deploy.
We created a basic project and only modified the autonomous code (adding no other code) and setting both left and right to same number. The same issue occurs - only one side runs.
Unread 17-03-2014, 10:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Autonomous Mode - only one side operates (Labview)
If you're setting both inputs to an Arcade Drive function to the same number, you're actually telling it to turn as much as you're telling it to drive forward. That'll have the effect of keeping one side's wheels stationary so that the robot makes a tight circle.
Instead, just use the Y input to set the speed, and leave the X input at zero for no turning.
Unread 07-04-2014, 19:00
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
Rookie Year: 2013
pastelpony will become famous soon enough
Use ArcadeDrive to turn the robot and AutoDrive (or whatever its called) to move it forward.
