Team 3309 Presents: Gateway
![]() Reveal Video Shooter
Ground Pickup
Drivetrain
See you at the Los Angeles and Las Vegas Regionals! Last edited by dcarr : 17-03-2014 at 14:25. |
Re: Team 3309 Presents: Gateway
Turned out great, David! You guys are quickly becoming a favorite from California.
Do you have photos of your drive setup? Also, how robust is that intake arm? Best of luck! |
Solid looking robot! Good luck in L.A. and we will see you on the field in Vegas...
If you have the weight, you may want to consider adding some sort of protection or shielding for those intake deployment cylinders. 1712 has a similar set-up, and we noticed during practice that a direct hit from a flying ball can cause the piston rods to bend. Granted, we're using 3/4" bore cylinders, they're more exposed, and it was first noticed during catching practice (and later repeated during aerial inbounding practice). With your larger bore (1 1/4"??), utlization differences, and more structural elements near the cylinder the risk may be less for you than it was for us. However, we added some aluminum bars above ours to remove the risk of having our intake get stuck in the deployed position because of a bent piston rod.
*Zygmont, note "borrowed" ![]() |
Seriously, looks like a great robot. I hope I get a chance to see it at Champs. |
yeah, there is a few other parts that can break too. with the limits of fabricated spare parts, I will have to favor saving the weight for fabricated spare parts. COTS spares on the other hand don't have a limit. I am keeping my spare cylinders in their packaging, I hope to return them if luck is in my favor.
We practice with 3476 a bunch, so far we have been holding up to their ramming speed. We have gotten whacked by their intake a few times. Not sure how we will do in the 6 robot scrum. I do like the 4ft per second tank mode. You should ask code orange about being the receiving end of bulldozer mode ![]() Last edited by Mark Sheridan : 17-03-2014 at 16:58. |
Bot looks great!! Good luck at LA and LV.
#10
Looking good! We'll have the great pleasure of competing with, and against you, in both Los Angeles and Las Vegas.
...and maybe an in between scrimmage. |
