Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 19-03-2014, 13:53
ashb1025 ashb1025 is offline
FTC #6095
ashb1025 is an unknown quantity at this point
Autonomous Ideas/Help
Hi, I was thinking about making a program that makes our robot follow people or make it follow a laser pointer but I have no idea where to start and could use some help.
Unread 19-03-2014, 14:32
KPSch KPSch is offline
AKA: Ken Schenke
FRC #1987 (Broncobots)
Rookie Year: 2013
KPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to all
Re: Autonomous Ideas/Help
A 120 pound robot that follows people is a bad idea for safety reasons. You might be able to track a laser pointer with vision tracking. An ultrasonic range sensor could be used to measure distance to the surface reflecting the beam.
Unread 19-03-2014, 14:33
AKA: Ken Schenke
Rookie Year: 2013
I just noticed you were FTC, not FRC. As long as the person was the closest object to the robot, an ultrasonic sensor could be used to follow that person.
Unread 19-03-2014, 15:49
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
In our outreach LEGO Mindstorms camps we have an activity where we use a LEGO Mindstorms Ultrasonic Sensor and we program the robot to follow a person. The general algorithm is this:
(1) If we see something within visual range, but it's farther away than our minimum following distance, move forward.
(2) If we don't see something, turn the robot left and right (the ultrasonic sensor is mounted in a fixed orientation on the robot) an increasing amount until we see an object.
What will happen is someone will walk in front of the robot, and the robot will follow the person. If the person turns, the robot will "lose contact" with the person, and will begin scanning for the person. Once it finds the person again, it will continue to follow the person until the person is out of the range of the sensor, and then it will re-acquire the person. Unfortunately the Ultrasonic Sensors don't do any phase shifting of the signal so it can determine ownership of the reflected signal, so using 2 ultrasonic sensors doesn't give you 3D vision (and thus the ability to detect if the person is veering left or right) - using 2 ultrasonic sensors just confuses your sensors.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 20-03-2014, 13:23
FTC #6095
How would I set up the code? Like I don't know what values or functions or anything for it? I am at a mostly complete loss trying to do this.
