Go to Post I even liked the Bieber commercial. - Andy Baker [more]
Unread 19-03-2014, 20:42
afclsn afclsn is offline
Adam Claussen
AKA: Adam Claussen
FRC #4474 (Silver Circuit)
Team Role: Mechanical
Rookie Year: 2013
afclsn is an unknown quantity at this point
Victor 888 Not responsive
When the code is not enabled, the indicator light flashes orange, and when the code is enabled the light flashes slowly red. We have tried different pwm cables, and the problem persisted. Also we swapped the pwm cable and the ports on the digital sidecar that the pwm cable is in with the cable and port of a working victor, and the victor that was working before continued working, while the victor that did not worked acted as before, flashing orange when the code was not engaged, and flashing a red when the code was engaged. We also rewired the motor controller and are sure it is wired correctly. What could cause this? Is it a dead victor or is there some other mysterious issue that we are not aware of?
Unread 19-03-2014, 20:50
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
Rookie Year: 2010
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Victor 888 Not responsive
It's odd that the Victor is flashing red, the only reason an 888 should flash red is if calibration failed. Did you attempt to calibrate the Victor?
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 19-03-2014, 21:02
Adam Claussen
AKA: Adam Claussen
Rookie Year: 2013
Yes, we tried to re calibrate it, and it did not respond with the normal flashing green and red. It just continued flashing red.
Unread 19-03-2014, 21:09
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Does the motor move slowly, and/or do you measure voltage on the Victor's output terminals?
My guess is that the Victor is not calibrated properly, or the joystick is not returning to the neutral position.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 19-03-2014, 21:11
minhnhatbui's Avatar
minhnhatbui minhnhatbui is offline
FRC #3990 (Tech for Kids)
Rookie Year: 2011
minhnhatbui is a jewel in the roughminhnhatbui is a jewel in the roughminhnhatbui is a jewel in the rough
Should be related to calibration issue. Try to calibrate again.
http://content.vexrobotics.com/docs/...UserManual.pdf
Mentor for Équipe Team 3990: Tech for Kids
www.team3990.com | facebook.com/team3990 | @team3990
Regional Winners, Montréal 2012, 2013, 2014
Finalists, NY Tech Valley 2014
Semi-finals, Curie 2013
Rookie All-Star, Championship 2012
Unread 19-03-2014, 22:18
alex.lew alex.lew is offline
college student
FRC #1912 (Team Combustion), FRC #0558 (Elm City Robo Squad)
Rookie Year: 2012
alex.lew will become famous soon enoughalex.lew will become famous soon enough
If not the victor itself, it's almost definitely a joystick error. We had a similar issue with 2 talons and a victor, the joystick axes simply feed a non-zero value to the speed controller.
Unread 19-03-2014, 22:39
Adam Claussen
AKA: Adam Claussen
Rookie Year: 2013
That's what I thought but we tried to calibrate it and when we pushed the calibrate button it would not go to the red/green blink. I am sure we were calibrating it correctly because we calibrated 3 other victors right before trying to do that one. We also restarted everything and tried again to calibrate it but had the same issue. Right now the motor doesn't turn, but I forgot to measure the voltage across the terminals. I will try to calibrate it again when we open it on Friday at our regional (we used the last of our open bag time today). Currently the motor attached to the victor will not turn at all. If anyone has any other suggestions please let me know, but other than that we don't know what else to do.
Thanks,
team 4474
Unread 19-03-2014, 22:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Per the Victor user manual (http://content.vexrobotics.com/vexpr..._20130118.pdf), it indicates failed calibration, as others have said.
Start by checking the code and the wiring - are you actually sending one of the joystick axis to the correct port for that victor?
You said you correctly calibrated 3 other victors before hand... can you temporarily swap the PWM cable from one working victor to the bad one and try calibration again (keep the DSC side the same, just unplug from the good victor and plug it into the bad one)?
Have you tried replacing the victor?
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 19-03-2014, 23:07
Adam Claussen
AKA: Adam Claussen
Rookie Year: 2013
I am almost certain that we are sending a joystick axis to correct port for the victor. We have already tried switching the pwm but keeping the dsc the same, but we did not try calibrating it like this. We will try this first thing Friday also no, we have not tried switching the victor, because no mater how dumb this sounds (and I admit that it is) we don't currently have a spare. If none of this works we may be able to borrow one from another local, better established team. This only being our second year we don't have many spare parts, and we unfortunately don't have much of a budget for spare parts. Thank you for your advice.
