Go to Post that....was more far-fetched than the tennis ball I threw for my dog earlier today... - TeknicllyInsane [more]
Unread 21-03-2014, 14:15
Trish Fisher Trish Fisher is offline
FRC #2240 (Brute Force)
Rookie Year: 2012
Trish Fisher is an unknown quantity at this point
Sonic Shifter pinion gears fall off when shifting
Pinion gears keep falling off each time the motors is shifted.
The retaining rings are on all four of the pinion gears on the motor shafts.
This is happening on our practice bot, but it wasn't happening on our competition bot before we put it in the bag.
http://www.andymark.com/ProductDetai...de=AM-2509_118
Tomorrow at our meeting the students will:
1. make sure motors are tightened in gear box
2. make sure gear boxes are tightened together
3. fix bearings in center wheel
4. check rest of bearings
5. put gears back on with collars
6. possibly add more lube
Does anyone have additional ideas?
Unread 21-03-2014, 14:27
Chris is me's Avatar
AKA: Pinecone
Re: Sonic Shifter pinion gears fall off when shifting
By falling off, I assume you mean the gear is leaving the shaft? With two retaining rings and a properly sized key, this certainly should not be an issue. An 8mm collar or two, while overkill, would do the job here if your retaining rings are not working.
Unread 21-03-2014, 15:10
mikemat mikemat is offline
Rookie Year: 2011
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
Are the cim output shafts on your practice bot shortened?
