Go to Post What about "I h8 Autonomous Mode" (for the programmers who actually have to make the robots work)? - Tristan Lall [more]
Unread 22-03-2014, 17:08
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Rookie Year: 2014
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
Legal battery chargers this year.
My team was wondering about what chargers are legal this year. We have heard that in past years there has been a 6 amp limit but this year we cant find anything talking about chargers in either the game or administrative manual.
Does anyone have any clarification on this rule?
Unread 22-03-2014, 17:16
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Rookie Year: 2011
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Legal battery chargers this year.
You can not charge a battery at a rate higher then 6 amps, (about the max charge rate of the batteries we use) This is stated in the safety manual.
This is generally enforced by limiting chargers to a max rate of 6 amps. However certain special conditions could allow a charger with a max rate greater then 6 amps to be used.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 22-03-2014, 17:19
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
http://www.chiefdelphi.com/forums/sh...3&postcount=11
Unread 22-03-2014, 21:31
AKA: Max Westwater
FRC #5254 (HYPE)
Rookie Year: 2014
Thanks for the help.
My team is also wondering how many batteries your team brings to competition. We have a 6 CIM drivetrain and are worried about not having enough batteries fully charged.
Unread 22-03-2014, 23:17
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I consider 6 batteries to be an absolute minimum for a competition. Now that we are a district, with 12 matches (at least) per event, this became an even more solid conviction. We have a charger cart with four chargers that makes us comfortable with 8 batteries. This partly due to doing only one match per battery and monitoring the battery state after each match just before it joins the charging cycle. At matches we set the charge rate to 4a.
Giving each battery a name will also help you keep track of the good versus the marginal performers and allow a cogent cycle of use to be formed for them. We use a battery beak to monitor the battery state. They are pricey, but the beak helps you manage your several hundred dollar investment in electron storage and feel confident that your robot has as decent a chance at getting through a match as you can give it. You also get the chance to see which of your stable of energy may only be suitable for practice or control system testing.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 22-03-2014, 23:18
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
With 6 CIMs, you'll most likely want a new battery every match. This will come up most in eliminations. There are extra batteries available for teams in eliminations that need to play back to back matches, but plan on having at least 6 batteries fully charged and ready to go for eliminations.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 22-03-2014, 23:27
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Rookie Year: 2012
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
We have a 3-charge bank and bring plenty of batteries. I think we bring 10-12ish, but I am not sure. We change the battery before every match.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 23-03-2014, 01:49
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
Rookie Year: 2011
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
I think the amount of batteries will depend on how you use them. Previous years with us not using pneumatics, 4-6 batteries with two chargers was very adequate.
If you have a lot of pneumatics and plan on pre charging a bunch of tanks in queue you could need quite a few batteries and chargers to keep up.
This year we are using a lot of pneumatics and are bringing 10 new batteries and some of our previous years batteries for pit demos (LED shows and such for the pit visitors). We will be bringing 5 (6amp) chargers as well. We also plan on using the previous matches battery for the pneumatic pre charging and swapping in a fully charged battery when the robot is ready to load on the field.
Good luck this season,
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 23-03-2014, 10:20
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You might want to be worried about tripping the main breaker. At least two teams in Wisconsin tripped multiple times with a six motor drive train.
Al
WB9UVJ
www.wildstang.org
Unread 23-03-2014, 18:51
AKA: Max Westwater
FRC #5254 (HYPE)
Rookie Year: 2014
We were kind of worried about this being an issue. I hope it doesn't end up being a huge problem.
Unread 23-03-2014, 20:14
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Oh, is that why 2481 kept dying during eliminations? I know in at least two (maybe it was three) matches, they dropped dead in the middle of the field (no signal light), after a rough pushing match.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 23-03-2014, 23:44
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Yes in between SF 1 and SF 2 we switched out the main breaker. After that it never flipped again. We were also cooling it between matches. Realize we had 8 motors for our swerve drive. 4 CIMs and 4 BB RS775(I think). The wires between our battery and PDB were getting quite warm so we are planning on lowering the gauge for nationals to better handle the current.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 24-03-2014, 00:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I saw three robots with tripped main breakers at the Boilermaker regional. In each case, only one of the wires was warm. The apparent cause was not too much current, but simply too much heat from a poor connection caused by a loose nut where the wire connects to the breaker.
Loose main power connections -- on battery terminals, SB-50 connectors, main circuit breakers, and/or Power Distribution Board inputs -- were unfortunately very common. It'll be interesting to see if the logging feature of next year's PDB will help convince certain teams that their general animosity toward "the FMS" is misplaced, and that their loss of robot control on the field can usually be prevented with a bit more attention in the pits to checking and maintaining the robot's electrical system.
Unread 24-03-2014, 00:11
SoftwareBug2.0's Avatar
SoftwareBug2.0 SoftwareBug2.0 is offline
AKA: Eric
FRC #1425 (Error Code Xero)
SoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant future
I didn't realize teams did anything different.
  #15   Spotlight this post!
Unread 24-03-2014, 09:35
Unsung FIRST Hero
Rookie Year: 1996
Kyle,
I think the drivers just became a little less aggressive in the subsequent matches as I had suggested. If you go back to the old ways, this problem will revisit you. You know I have a vested interest in keeping you guys running, you gifted me and I am returning the favor.
Al
WB9UVJ
www.wildstang.org
