Go to Post We all need to keep things in perspective. When you look back at the entire 2005 FIRST season, is your entire experience defined by the presence of a little cloth flag on the play field? - dlavery [more]
Unread 22-03-2014, 18:07
Potatonator's Avatar
Potatonator Potatonator is offline
much potato very robot wow
FRC #4360 (Spudnik)
Rookie Year: 2012
Potatonator is an unknown quantity at this point
Communication Issue
Half the time, the robot communicates just fine. The other half, the communication randomly drops in and out, and sometimes stops working entirely. We thought we had fixed this, as we'd already posted a thread here and gotten a solution (here). But now the same issue is happening again, and we don't have long to fix it. Help, please! (by the way, sorry if I shouldn't have posted another thread for this, but I wanted to make sure we got help before competition. And we're leaving in four days, so we don't have very long.)
Unread 22-03-2014, 18:22
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Communication Issue
This may be a bit of a dumb question, but how are you testing this? Your robot should be in a bag...
Unread 22-03-2014, 18:33
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Robot Access Period for district teams, possibly.
Potatonator:
Double check your wiring again, as this is the most likely cause.
If you can't get it fixed by the competition, then after you get inspected, find the CSA (control system advisory, bright orange hats). They will be able help you troubleshoot the issue.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 22-03-2014, 18:34
FRC #4360 (Spudnik)
Rookie Year: 2012
The robot is bagged. We made a basic robot out of leftover parts, and are testing stuff out using that. So we are using a different router, but it's the same brand and configured the same way.
Unread 23-03-2014, 09:09
You haven't mentioned what the log file shows or what the DS LEDs show. Consider yourself lucky that you can get the issue to show itself half the time. That gives you lots of debug time.
Greg McKaskle
