Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 24-03-2014, 13:52
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Size of Regional Banner
I was asked to make a pvc stand for our regional banner from 2010. Unfortunately I can't get a hold of the banner till this Thursday at competition. I am looking for either an schematic that someone made out of pvc to hold one banner, or the general measurements of the banner including the best pvc to fit through the holder at the top and the bottom.
All help would be much appreciated.
Tomy Cummings
Unread 24-03-2014, 14:08
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Size of Regional Banner
Banners are 3 ft wide x 5 ft tall. The width of the hanger should be a little bit more than 36" wide to fit easily, and something more than 5 ft. tall to be off the ground. 3/4" or 1" pvc will fit thru the top loop. 1/2" pvc might not be as rigid as you would like.
Unread 24-03-2014, 14:15
Did you use the grommets to hang it or the through hole at the top? If you used the through hole then what size pvc did you use? Thank you for the quick response, much appreciated.
Unread 24-03-2014, 14:19
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
Originally Posted by tomy View Post
Did you use the grommets to hang it or the through hole at the top? If you used the through hole what size pvc
There are no grommets in our banners. 3/4" pvc fits nicely, 1" pvc will also fit.
Unread 24-03-2014, 14:23
Thanks you for the information and quick response!
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
It also fits through 1 1/4" PVC, it is a little tight but once you get the PVC in, it works great.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
