Ball Bounces Lands on Top of the Truss
I know one of the first things many people thought of this year in the first week was "What if the ball lands on the truss". The rules were even updated to give a solution to this problem. Personally, I thought this would NEVER happen. I don't know if it has happened yet this year, but it did this weekend In Finals 3 of Southington, 195 went for a shot, but it went high and bounced back on to the field. It hit right about at the white line then found it's way onto the truss. It took the refs a few seconds (although it seemed like it was much longer from behind the glass) to shake it off, it seemed like the ball just didn't want to come off. The video below is from behind the glass. Although somewhat blocked by the drivers, you can see the ball land on the truss. A better video will be available soon.
http://youtu.be/Qk4oPTdtlbQ Will this ever happen again? We have just a few weeks left to find out. |
Re: Ball Bounces Lands on Top of the Truss
This happened at the Arizona Regional as well. Although, I don't remember which match it was.
107??? managed it at Escanaba.
They should just switch to a ball caught on the truss if done "un-intentionally' should be called as a rematch if the ball can't be dislodged in x amount of time by field staff.
They should have not had a flat top to the top of the truss! but was an entertaining point of day, and did not affect outcome.
A simple polycarb covering like the high goals would fix this too.
Of course. Having the reset crew fixing something outside the course is 9 million times better than anything on-field, but it still was quite comical, especially considering the purpose those panels were supposed to serve
#10
Those panels were there to stop balls from re-entering play after scored. they have nothing to do with causing them to continue through the goal.
#11
I also feel that the field should really have been netted as was done last year. The fact that an alliance's single game piece can inadvertently be ejected from play, and that returning the ball to play sometimes requires 3+ people seriously disrupts the flow of the game. FIRST really dropped the ball (failed to drop it?) in terms of field design. |
#12
The entire netting system and the support poles would be knocked down by a ball going into it.
#13
We had one match back at Arkansas where our robot launched the ball, it hit the top of the truss and rolled across nearly the entire distance of it before falling off. We watched as it slowly rolled and nearly stopped, but it had just enough gas to make it off. Pretty exciting.
#14
These are rented trusses. They are standard fabricated trusses that are used for audio/visual equipment. FIRST does not own them, nor do they build them.
