Re: Ball Bounces Lands on Top of the Truss
Rotate them 45 degrees then.
Oh the ball landed on the scoring side of the truss so the alliance got the ten points. If the alliance had their wits about them they should have placed a robot or two underneath it ready to catch it when it got shaken loose. |
Happened at Escanaba and again at Boilermaker. Both times the refs nearly shook the thing apart getting it off there. Neither really ended up affecting the outcome of a match though, was more funny than anything.
Can you say end game?
As far as i remember there were two or three of these incidents at the Escanaba competition, it was pretty entertaining to see and not too big of a problem for the ref to shake down.
![]() Quote:
#11
In our situation, the ball did not get up there in an attempt to score over the truss, it got up there after a rebound off of the goal. Also, you cannot know for sure which side it will fall off of the truss. If it falls the right way once and that alliance receives truss points, then later another alliance does not receive points because it falls backwards, it is not fair to the alliance where it falls backwards. I would much rather have the ball back on the field in a timely fashion than worry about getting the truss points.
#12
