Go to Post Teams need to make 'don't be a jerk' a part of their culture, and that culture needs to be explained to the parents who travel with you - Libby K [more]
Unread 25-03-2014, 11:03
nick1023 nick1023 is offline
FRC #1023
nick1023 will become famous soon enough
ISO 120T 5mm Pitch HTD Timing Belts (8.5mm width)
We puchased 120T 5mm HTD timing belts via Vexpro for our drive system. Vexpro, WCP and the Robot Space are all out of stock on these. Vexpro customer support said not to expect any to show up before the end of the FRC season.
The hex shaft pulleys also purchased from Vexpro are 17.5 mm wide. The "9mm" wide belts are actually 8.5 mm to so that two can fit on the 17.5 pulley. I cannot locate another supplier who has actual 8.5mm belts instead of 9mm.
If you have spares to sell or can suggest a supplier for 5mm pitch 120T HTD timing belts with an 8.5 mm width I'd appreciate a link.
Thanks!
Nick
1023 Bedford Express
Unread 25-03-2014, 11:15
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: ISO 120T 5mm Pitch HTD Timing Belts (8.5mm width)
I believe that most generic "9mm" belts are actually 8.5mm, rather than exactly 9mm. Someone from vex can correct me if im wrong, but i dont think they did anything special to their belts to make them fit this way.
If that doesn't work out, you can purchase raw pulley stock and make a custom pulley of slightly greater width.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 25-03-2014, 11:24
FRC #1023
I ordered some from B&B manufacturing and found that to not be the case. They come out at 8.9mm. Too tight to fit two onto the Vexpulley and a real tight fit for one vexpro belt and one BB belt on the Vexpulley.
Unread 25-03-2014, 11:27
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Gates have 120 tooth 5mm HTD belts. 600-5M-09 Check their web site for a local distributor. BB Man sells them on line, but they are not showing stock. Depending on how much adjustment you have you might have to go up or down a size.
Never mind these are 9MM belts.
Unread 25-03-2014, 14:17
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Reprap style belt splitter, maybe?
http://reprap.org/wiki/Belt_splitter_jig
Parametric 3D Pinted Belt Splitter
Acrylic/Lexan laser cut or hand cut belt splitter
I was considering this as an option when it looked like we might need some 8.5mm belts in lengths not carried by Vex. I would assume you'd start with a 15mm belt and either split it 7.5/7.5 or 8.5/6.5 and get 2 or 1 belts out of it depending on your load requirements. There's downsides, of course. Namely, if you can't cut through the fiberglass tension member, your belt width is going to change slightly. And it's obviously not going to be quite as clean or reliable as a factory cut belt.
Unread 25-03-2014, 16:44
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
Rookie Year: 2011
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
A few seconds with Google turns up this custom HTD belt supplier. They will cut any width you want, such as 8.5mm.
http://www.beltingonline.com/5mm-htd-timing-belts-4575
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 25-03-2014, 16:51
Rookie Year: 1998
Oh right. I saw those guys. And then noticed they were based out of England, which makes things slower and more complicated...
Unread 26-03-2014, 10:29
weberr's Avatar
weberr weberr is offline
AKA: Ron Weber
FRC #3641 (The Flying Toastters)
Team Role: Coach
Rookie Year: 2011
weberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond reputeweberr has a reputation beyond repute
Try Vbeltsupply.com we buy all kinds of belts from them.
