Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 28-03-2014, 18:43
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
Rookie Year: 2012
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Beginner Java Help - Question 1
Hello! I'm new to Java (we're planning to switch to it next year after passing the last three years using Labview) and I have one important question. In the "Getting Started with Java for FRC" pdf, it shows the following code for an autonomous that drives in a square pattern by driving half speed for 2 seconds, then turns 90 degrees. This is repeated 4 times :
Code:
public void autonomous() {
     for (int i = 0; i < 4; i++) {
          drive.drive(0.5, 0.0); // drive 50% fwd 0% turn
          Timer.delay(2.0); // wait 2 seconds
          drive.drive(0.0, 0.75); // drive 0% fwd, 75% turn
     drive.drive(0.0, 0.0); // drive 0% forward, 0% turn
What I don't understand is why it's a 75% turn for a 90 deg turn? Is there some way this was calculated?
Thanks!
P.S. I called this "Question 1" because I know that I will have other questions about Java in the future!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
