Go to Post Real coaches dont use "strategy assistants" during matches. - Rick [more]
Unread 31-03-2014, 15:15
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Re: How to improve power in piston shooter
Originally Posted by nuclearnerd View Post
This one has a CV of 1.0 with a 1/8 npt port, Which is 3 or 4 times larger than the SMC / Festo valves you can get from AndyMark or Vex. We haven't used them though, so don't consider this an endorsement:
http://www.mcmaster.com/#6425k11/=rc3uws
FRC558 will endorse them, they are currently running well on our machine.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 31-03-2014, 15:31
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Cool. Do you have the actual manufacturer and model number then? It would be nice to look up the original spec sheet.
Unread 31-03-2014, 16:00
AKA: Justin Foss
Sure, they are made by Numatics Inc.The link should take you right to the product page.
Unread 31-03-2014, 21:22
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
Rookie Year: 2011
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
We use the Nitra AVS 3211-24d solenoids from Automation Direct.
http://www.automationdirect.com/adc/...)/AVS-3211-24D
These are 24v with a Cv of .78. We use these on 10" Bimba 1.5" bore cylinders and have been really happy with them.
Plus we used the product voucher from FIRST... Even if you do not use the voucher they are about 21.00 each.
Good luck
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 31-03-2014, 15:33
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Originally Posted by LR_connor View Post
Thank you for the information do you have any recommendations of where we can get some?
The brand is Norgren and they can be found on McMaster Carr
Faridodin "Fredi" Lajvardi KD7WKD
Unread 31-03-2014, 13:40
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Rookie Year: 2011
Jibsy will become famous soon enoughJibsy will become famous soon enough
We are currently using our pistons as an extra push for a pass as we are a inbound robot. Our pistons are not strong enough to shoot over the truss and i feel as though it would be a nice improvement to get working. Any help on how to get pistons to shoot higher and farther would be greatly appreciated.
Depending on your setup, a potentially easy improvement is to add gas springs alongside the pneumatic cylinders to assist them on the way up.
I'm surprised that I haven't seen this done yet given how much it could add.
All of the force that the cylinder is using to launch is also being used to retract (not as strong on retract, but still packs a punch). Rather than having all of that go to waste, you can use it to store up energy in a gas spring. Something like these:
http://www.mcmaster.com/#gas-springs/=rc2sdb
You may also need to employ some of the tricks people have mentioned already about increasing the flow rate of your cylinder - otherwise the spring may just be slowed right down resulting in more than enough power, but not enough speed.
Best of luck!
Unread 31-03-2014, 14:18
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Best of luck!
Nearly every pneumatic launcher I have seen doesn't plumb the retraction of the cylinder at all. Most of them rely on gravity for return. This allows the cylinders to fire much faster as they don't have to exhaust through tubing or a solenoid.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
