4'' Plaction on AM14U?
Has anyone swapped the 4'' HiGrip KOP wheels with 4'' plaction? If so, how did you account for the difference in width of the wheels? We're considering doing this on our robot, but are unsure if the plaction wheels (which are wider) will actually fit for the center wheel, which has two pulleys on it with little/no clearance on either side.
How much wider are they? You could chuck em up in a lathe and skinny them up a little
Re: 4'' Plaction on AM14U?
They should work. AM sells a plaction upgrade kit and it doesn't include wider churros. You might need to make new spacers though.
Plaction upgrade kit Last edited by Mike Marandola : 01-04-2014 at 21:35. |
It's really hard to do. We ended cutting down the center wheels and created our own custom spacers.
What do you mean by cutting down your center wheel? How much did you have to take off?
The red part in the picture is what we took off. Last edited by orangemoore : 01-04-2014 at 22:58. |
Its quite do-able. We had to shave down the wheels, on a lathe, to where the pulleys were nearly flush to the wheel and cut down the hex spacer for the center wheel to where the pulley was nearly flush with the outer plates.
