Re: Swerve Drive vs Mecanum Wheel drive?
Though this is the practice ramp (only pic I have on me) we could quite easily
Also 2012 bump? no problem I loved our mecanum robots, they worked really well. They work an unbelievably better when controlled by encoders and PID as well, the only reason we stopped using them is because we hate getting ruled off scouting lists for no reason but them, even though in 2011/2012 we pushed so many robots you would not even imagine. And mecanum is really light. in 2012 and 2011 we used ToughBox nanos with the output direct driving the AM 6" wheel. Any 4 CIM chain tank drive is going to weigh just as much. Also they take up almost no space (note our 4 sided intake!) Last edited by BBray_T1296 : 04-04-2014 at 01:20. |
This is another reason mecanum can suck, because of the number of teams that don't utilize the full benefits of the drive most competitive teams will cross you right off of pick lists. You have to SHOW that you can rock it well with some epic driving to avoid that fate(this is one of the things 1678 looks for when scouting).
Even the belief that swerve drive done correctly is always better than mecanum drive done correctly is misguided. The teams that use swerve drive year in and year out effectively tend to have great organizations along with better than average resources. I'm not convinced these team's competitiveness entirely derives from their drive train. Likely they'd be just as successful with a 4/6/8 wheel tank drive, a mecanum drive train, or some other drive train. |
Personally, I like both Mecanum and Swerve. However, my team decided that we weren't really looking to make a swerve drive due to the resource and experience concerns. Instead, we went with a modified octanum drive. With butterfly modules comprised of mecanum and colson, we feel as if we have achieved a similar performance to Swerve, but without several of the sacrifices.
When considering drive trains, you must consider everything. Do not make a hasty decision whilst either scouting or building. I suggest looking up 1114's drive train documentation. Implementing a system that allows for decisions based off of quantitative data enables a team to make intelligent choices. |
Team 174 Arctic Warriors do belt driven swerve drives every year. It's honestly ridiculous if you get a chance to see it but it works well and it's really cool.
I have never personally seen a swerve drive in person, but only in videos. This is the first year that my team has used mecanems. We decided that we also wanted to develop a new drivetrain to go with it. It is sort of an octanum drive base. We used 4 4" mecanem wheels and 2 six inch traction wheels. We have gone through 2 district events and gotten second in one. The first event we got pushed around a decent amount, but in the second, we got pushed around less as we got better driving. The traction wheels also allow us to play some pretty good defense too. The choice that teams make between tank, mechanems, and swerve should be based on their desired strategy that year. I have found mechanems to be the greatest wheels i have seen when lining up for the one point goal. Since they can "drift" it makes it easy to drive up quickly, and then move side to side to put the ball in quickly. I have seen numerous teams have to line up multiple times when they try to get the ball in.
To be fair, one of the finalists on curie in 2008, 2171, was running mecanums. And IIRC they were actually using them as well (to weave through traffic).
Last edited by Ben Wolsieffer : 06-04-2014 at 16:06. Reason: Added on a new part |
Field oriented control has been around for a number of years. It's built-in to LabVIEW and WPILib for Java and C. |
#10
We have actually never had any problems with our encoders, even when one broke, the rest of the PIDs made up for it.
As for Field Centric, we never used it. It is way faster to do robot centric. 85% of the time, we don't use the strafing feature of the mecanums. But, the most important 15% we use them. (Like lining up the 1pt goal and lining up for inbounding) And that has made it worth while |
#11
It's most unique aspect is that it could automatically correct its orientation when we were pushed or lost traction on a wheel, which made our system much easier to control than it would have been without it and it allowed us to travel in an absolutely straight line, unlike it the past where going sideways often went in an arc instead. This prevented us from needing to be so obsessive about weight distribution, because we could just let software fix our problems.
#12
... and give credit where credit is due ![]() |
#13
I would tell where specifically I got the idea from on CD, but I don't really remember anymore. ![]() Last edited by Ben Wolsieffer : 06-04-2014 at 17:08. Reason: restructured sentence |
#14
#15
src/org/usfirst/frc2084/CMonster2014/commands/FieldCentricMecanumDriveCommand.java
