Go to Post Cue all the jokes about natural selection in the Darwin division - TDav540 [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 03-04-2014, 23:45
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Team 1418 Python Robot Code released for 2014
This code is released from Team 1418's 2014 robot. We used python for the robot software, and also implemented custom driver station software using Python & PyGTK.
1418 had a dominating performance at Richmond at the Virginia Regional, finishing as the #2 seed, and led the #2 alliance to the finals with teams 2383 and 435. They were awarded the Industrial Design award for a variety of reasons, including their simple but effective robot design, multiple autonomous modes and useful touchscreen driver station interface.
At the Greater DC Regional, they had a rocky start and ended up finishing as the 7th seed, but led the #6 alliance to the finals with teams 1885 and 2537.
Robot Code highlights:
  • Full pyfrc integration for testing & robot simulation
  • Unit tests over the robot code with 70% code coverage
  • Automation of core catapult functions
  • Complex autonomous mode support
    • Multiple working autonomous modes used in competition
      • Two balls - uses a gyro to make sure the robot drives straight
      • Single ball shoot
      • Single ball hot goal shoot
    • Automatic support for tuning the autonomous mode parameters via the UI
The autonomous mode framework developed for this season is pretty cool, and we found it significantly easier to develop autonomous modes using this framework. After some cleanup, it will be integrated into pyfrc so others can use it.
Driver Station UI Highlights:
  • Comprehensive autonomous mode support
    • Fine tuned autonomous mode parameter tuning
    • Multiple autonomous modes supported
  • Graphing of robot catapult parameters
  • Visual display of robot status
  • Most robot features can be controlled from the UI
  • Image processing features:
    • Interactive tuning of threshold parameters
    • Comprehensive debugging support
    • Visual indication of hot goal detection
    • Static and live image processing
    • Can support multiple cameras
  • "Hot goal in a box" mode
    • Start the dashboard only showing the camera feed and the image processing tools.
    • Transmits 'IsHotLeft' and 'IsHotRight' to the robot via NetworkTables
You can download the code at http://www.virtualroadside.com/FRC/#VaeVictis2014
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
