Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 07-04-2014, 12:38
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
Problem with AM 9015 motor
Hi guys
I have an AM 9015 motor that I am running from a 12v power supply
when I turn it on, it spikes and draws around 1.5 amps and then settles to 1.2 amps like the free current specs say
usually when I run it, it spikes to 1.5A and then runs for a .5-3 seconds and then stops, I can see the fan in the back twitching but it won't turn (happens in both directions)
other times it won't start at all and turning the motor a few degrees causes it to repeat the symptoms above (run for a bit then stop and twitch)
all of this happens without a gearbox attached but when I attach a versaplanetary 10:1 the issue is the same
my initial thoughts are it is not getting enough current or the wire is too small to give it enough current (20 AWG) but according to the power supply it is not trying to draw much more current so that is confusing me
any ideas on why this is happening? thanks
Unread 07-04-2014, 12:42
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Re: Problem with AM 9015 motor
In some motors like those and the Fisher Price motors, if the mounting screws are too deep they will jam into the internal coils and mechanically halt the motor. Otherwise, it is possible that some of the little fan blades at the back have broken off and are in the way. I cannot think of any reason a healthy motor would fail other than these reasons (the motor will run just fine with a few fan teeth missing, so long as they are cleared)
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Have you tried a second/replacement motor? It sounds to me like there might be an intermittent short, similar to the RS-775 issues a number of years ago.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 07-04-2014, 12:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
what is the maximum current rating on the power supply?
