Thread Tools |
Rating:
Display Modes |
How to loop peices of code forever?
Hello I am a programmer for my school's robotics team and engineering class and i ran into a code problem. A team project is to program a claw bot that when a button is pressed it will follow a line with encoders and with the claw bot grab a box line track backwards and let go of the box, it is supposed to do this forever when the button at the beginning is pressed. Not only that but when a button is pressed while its looping it will do this task one more time before ending the program. So my problem is that i can't get the code to run forever when the button is pressed, what happens is that the line track moves forever and never moves on to the next step. Here is how my code looks below.
PS: I know i didn't include the part when the button is pressed again it runs one more time. It's not included because that's not the problem. #pragma config(Sensor, in1, pot, sensorPotentiometer) #pragma config(Sensor, in3, LineLeft, sensorLineFollower) #pragma config(Sensor, in4, LineRight, sensorLineFollower) #pragma config(Sensor, in5, LineCenter, sensorLineFollower) #pragma config(Sensor, dgtl1, touch, sensorTouch) #pragma config(Sensor, dgtl2, Encoder, sensorQuadEncoder) #pragma config(Sensor, dgtl7, Encoder2, sensorQuadEncoder) #pragma config(Motor, port2, arm, tmotorServoContinuousRotation, openLoop) #pragma config(Motor, port3, elbow, tmotorServoContinuousRotation, openLoop) #pragma config(Motor, port7, rightMotor, tmotorServoContinuousRotation, openLoop, reversed) #pragma config(Motor, port8, leftMotor, tmotorServoContinuousRotation, openLoop) //*!!Code automatically generated by 'ROBOTC' configuration wizard !!*// task main() { if(SensorValue(touch) == 0) { motor[arm] = 0; } if(SensorValue(touch) == 1) { while(true)// i also tried while(1 == 1) { motor[elbow] = -63; wait1Msec(1500); } motor[elbow] = 0; wait1Msec(100); int threshold = 2000; SensorValue[Encoder] = 0; while(SensorValue[Encoder] < 210) { if(SensorValue(LineRight) > threshold) { // counter-steer right: motor[leftMotor] = 50; motor[rightMotor] = 0; } // CENTER sensor sees dark: if(SensorValue(LineCenter) > threshold) { // go straight motor[leftMotor] = 30; motor[rightMotor] = 30; } if(SensorValue(LineLeft) > threshold) { // counter-steer left: motor[leftMotor] = 0; motor[rightMotor] = 50; } } } { motor[arm] = 63; wait1Msec(2000); motor[elbow] = 63; wait1Msec(200); motor[rightMotor] = 0; motor[leftMotor] = 0; wait1Msec(1000); motor[arm] = -63; wait1Msec(1800); motor[elbow] = -63; wait1Msec(2500); motor[elbow] = 0; wait1Msec(1000); motor[rightMotor] = -43; motor[leftMotor] = -43; wait1Msec(500); } int threshold = 2000; SensorValue[Encoder] = 0; while(SensorValue[Encoder] > -450) { if(SensorValue(LineRight) > threshold) { // counter-steer right: motor[leftMotor] = -50; motor[rightMotor] = 0; } // CENTER sensor sees dark: if(SensorValue(LineCenter) > threshold) { // go straight motor[leftMotor] = -30; motor[rightMotor] = -30; } if(SensorValue(LineLeft) > threshold) { // counter-steer left: motor[leftMotor] = 0; motor[rightMotor] = -50; } } } |
Re: How to loop peices of code forever?
In your code, you have
Code:
motor[elbow] = -63;
wait1Msec(1500);
However, the block of code inside the while(true) loop is the only thing that will run forever. So at the moment, your elbow motor will run forever, but not the rest of the code. You should change your code so that the while(true) { ... } surrounds the entirety of the code that you want to run forever. |
You may want to posibly try this, I changed some things that might make it work a little better(or fail miserably):
Code:
void lineFollower(int speed);
task main()
while(true)
motor[arm] = 0;
motor[elbow] = -63;
wait1Msec(1500);
motor[elbow] = 0;
lineFollower(60);
motor[arm] = 63; // Brackets were wraped around this, is there suposed to be a loop or somthing here?
wait1Msec(2000);
motor[elbow] = 63;
wait1Msec(200);
wait1Msec(1000);
motor[arm] = -63;
wait1Msec(1800);
motor[elbow] = -63;
wait1Msec(2500);
motor[elbow] = 0;
wait1Msec(1000);
wait1Msec(500);
lineFollower(-60);
void lineFollower(int speed) // Can help clean up your code and make it easier to read
if(SensorValue(LineRight) > threshold && SensorValue(LineCenter) > threshold)
{ // Added a slight turn to have a bit of a gentler correction when the robot is not that far off the line
motor[leftMotor] = speed;
motor[rightMotor] = (speed / 2);
else if(SensorValue(LineLeft) > threshold && SensorValue(LineCenter) > threshold)
else if(SensorValue(LineCenter) > threshold)
motor[rightMotor] = speed;
else if(SensorValue(LineRight) > threshold)
else if(SensorValue(LineLeft) > threshold)
else
Yes I did put the while(true) brackets around the entire code, still it only moved the arm and line tracked forward forever. The code above me only went backwards forever. I can't believe these small problems sometimes.
Your code will keep line tracking while SensorValue[Encoder] < 210 in the forward-moving phase and SensorValue[Encoder] > -450 in the backward-moving phase. How did you arrive at these conditions? Are you sure that Encoder counts in the positive direction when you're moving forward, and the negative direction when moving backward?
I also changed the encoders to an absulate value comparison so it wont matter if you have the tick calculations wrong. Code:
void stopAllMotors();
task main()
while(true)
stopAllMotors();
motor[elbow] = -63;
wait1Msec(1500);
motor[elbow] = 0;
while(abs(SensorValue[Encoder]) < 210)
lineFollower(60);
wait1Msec(2000);
motor[elbow] = 63;
wait1Msec(200);
wait1Msec(1000);
motor[arm] = -63;
wait1Msec(1800);
motor[elbow] = -63;
wait1Msec(2500);
motor[elbow] = 0;
wait1Msec(1000);
wait1Msec(500);
while(abs(SensorValue[Encoder]) < 450)
lineFollower(-60);
else
motor[elbow] = 0;
motor[arm] = 0;
That code works but I think you misunderstand what i meant. I need this code to run forever once the button is pressed, once i press the button i can't press it again. The code has to keep running the same task once I press the button and the only reason I press the button again would be to end the while loop and stop the code.
I think your description of what you want is unclear. You're using the phrase "loop forever", but you also say you want to "run it once more and stop". What is it that you want the robot to do repeatedly -- is it the entire process of shuttling along the line moving boxes from one end to the other? Will you ever want to give any other commands besides "start" and "stop after you drop the next box"?
"The entire process of shuttling along the line moving boxes from one end to the other" Yes, So in the code should start up when a button is pressed and when it is the process should be looping forever.
#10
I don't know your level of knowledge so I can give you an appropriately tailored answer. My first thought is that this should be implemented as a state machine without any delays in it. The "start" state would do nothing, and would move to the "follow the line forward" when it sees the button press. When not in the "start" state I'd have the program continually check to see whether the button has just been pressed, and set a "prepare to stop" flag if so. If the flag is set, the final "drop the block" state would transition either to a "halted" state or back to the "start" state if you want to be able to start it up again.
Doing it sequentially with delays, as in the originally posted code, will make detecting the second button press very difficult. |
#11
Last edit Im going to do
Code:
bool continueRunning = true;
task checkForButtonPress();
task main()
while(true)
stopAllMotors();
while(SensorValue(touch) == 1) // Wait for release
StartTask(checkForButtonPress);
while(continueRunning)
motor[elbow] = -63;
wait1Msec(1500);
motor[elbow] = 0;
lineFollower(60);
wait1Msec(2000);
motor[elbow] = 63;
wait1Msec(200);
wait1Msec(1000);
motor[arm] = -63;
wait1Msec(1800);
motor[elbow] = -63;
wait1Msec(2500);
motor[elbow] = 0;
wait1Msec(1000);
wait1Msec(500);
lineFollower(-60);
else
motor[elbow] = 0;
motor[arm] = 0;
{continueRunning = true;
while(true)
continueRunning = false;
#12
Hey Kevin that Code almost works, It line follows back and fourth forever like its supposed to and stops when i press the button a second time. The only problem is that the arm keeps moving forever while its line tracking and the arm gets stuck because it never stops its first task. I'm trying to explain it right, the arm commands are supposed to stop once their done running for the time its given then switch to line following forward then move the arm a little you know to pick up the little box then switch to line following backwards.
I tried putting the commands inside where the line follower is because I thought since the line follower is working then the arm will too but the arm never stopped moving. ![]() |
