Go to Post Now if MTV had an episode of "Made" where the school's top jock wanted to drive a FIRST's teams robot to victory...now that would be a good one. - Koko Ed [more]
Unread 07-04-2014, 19:06
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Vex Pro vs. Gates HTD Pullies
I'm looking for objective differences between the vex pro line up of belts (here) and gates belts (example) and mcmaster (are they gates too?) (example)
We had some wear on our drivetrain belts (160T Vex 15MM), was wondering what better options were out there.
All opinions are my own.
Unread 07-04-2014, 19:12
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Vex Pro vs. Gates HTD Pullies
Are you sure the limiting factor causing the wear is an inferior product rather than a design or implementation issue?
We have noticed essentially no differences in performace, wear, etc. Perhaps you over tensioned, or used a pulley too small?
Unread 07-04-2014, 19:58
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
Team Role: Teacher
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
The few timing belts we have purchased from McMaster have been Goodyear branded (5mm HTD). I would look at the setup (c-c distance/tension/alignment/load) before looking to blame the belts.
http://www.goodyearep.com/ProductsDetail.aspx?id=4018
Unread 07-04-2014, 20:17
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
We've been running 9mm (in reality 8.5mm) VexPro belts for two tournaments this season and they have not visibly worn in the slightest. My bet would be your issues are with alignment or tensioning.
Frankly the only differences I've noticed have been in the branding. We used SDP-SI 5mm GT2 belts last year and the difference this year wasn't noticeable.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 07-04-2014, 22:10
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Rookie Year: 1999
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
What does the wear look like? Often time that can help you figure out what the problem is. If the teeth are stripping off, you are lundertensioned. If the belt snaps or the core fibers are breaking, you are either over tensioned or out of spec. You should be fine with 15mm. I know that 192 runs 15mm wide and doesn't have an issue. I was going to comment that a high CG also plays into how the belts wear, but then I remembered how ridiculously low your CG is.
If you want, you can run GT2 belts on HTD pulleys and have more strength than HTD belts on HTD pulleys (but less than GT2 on GT2). This won't fix the problem of if you are undertensioned.
-Travis
Unread 19-04-2014, 01:34
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rookie Year: 2012
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
We run 5mm pitch 15mm wide GT2 belts on 5mm pitch 22T GT2 pulleys with a fixed center to center and, as you said, haven't had any issues with them. We have a couple bases that have been running this same set up for 2 years and haven't needed any belt replacement.
This document is very helpful with diagnosing belt wear.
Unread 19-04-2014, 01:44
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
I think, almost more important than the belt tension is the number of teeth on your drive/driven pulleys. Smaller pulleys means more torque/tooth, and thus more wear. Larger pulleys distribute the load better and wear much slower.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 19-04-2014, 13:09
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
Rookie Year: 2010
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
You are probably not going to see much of a performance difference between pulley manufacturers provided they are making the tooth profile to spec. (I would guess that any reputable supplier will be) As others have mentioned, larger pulleys are better for higher working loads than smaller pulleys. The biggest factor in belt life is tension, unfortunately this is also the hardest thing to measure.
If you want a particular brand of belt or an odd width, instead of Mc-Master Carr, try looking up a local Gates dealer. I have found that they will generally get you the same or better product in a similar time frame for less. I have a few that I go to, if you are interested, send me a PM and I can send you their info.
Unread 19-04-2014, 21:00
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Chains lol.....
Our team has used chains forever and will never switch imaa chain lover.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
