Thread Tools |
Rating:
Display Modes |
Re: When will Divisions be released?
Not so far as you might think. Folks on Chief got pretty good at predicting WHAT the divisions would be (just not necessarily which was which); lasted up until around '07 or so, then someone realized that the algorithm was being seen through...and hit the random number generator. Nobody's been able to predict divisions since.
"Had Heard" = Rumor. - I got to visit the VIP area once and they weren't watching many matches.
the IIRC is because I couldn't remember which field is next to Galileo. In hindsight, I didn't add much to the discussion, my apologies. |
How could they both be in front of the VIP area if they are in opposite corners?
And kept the Curie Curse alive.
The Curie curse is the ONLY explanation for 2010. (I know, I know, it was crappy luck that 2041 got stuck in the goal)
I was there. I watched it, and was absolutely gobsmacked by what I was seeing. Not to put 67/177/294 down, but 469/1114/2041 was all but unstoppable, going undefeated right up until they were eliminated in Einstein Finals. (1114 was undefeated all SEASON until Championship, losing Curie Q100 [intentional 6v0 loss against 111 to guarantee themselves #1 seed] and Einstein F1/F2) Brilliant strategy on the part of 67/177/294 to capitalize on the bad luck and park one of their robots blocking the other goal when 2041 got stuck. Karthik has always said that winning championship is mostly about being well positioned to take advantage of luck going your way. If 1114 had played Q100 to win, they may have, but they ran the risk of a narrow loss, which would have allowed 111 to seed higher than them, and 469 was all but guaranteed to be the #1 pick. Last edited by Racer26 : 11-04-2014 at 16:09. |
Pretty sure 2041 got stuck in auton. I could be wrong though...
The ONLY explanation is that we were better in those two matches! |
#10
Anyone know of a way to get the schedule of events in a CSV format (other than doing it manually)?
#11
You could use the TBA API and save the necessary data as CSV...Python has support for requests, JSON and CSV, so you could check those modules out
#12
Because we all know that 67, 294, and 177 never build competitive robots, I mean they only have what, 60 blue banners between them?
#13
Your tone would change too, if everytime an achievement of your's came up it was defined as being "lucky" or the result of the Curie Curse. We know how much of an upset, but sometime we want credit for not rolling over an letting them walk right past us to the win. We had a strategy, we executed it in the first match. We won. That wasn't nessecarily luck that we beat them in the first match. In the second match, luck swung to our side, 2041 got stuck in the goal and 294 made sure they stayed there, we still had to play the rest of the match. 1114 was still scoring balls...and the match was close and not decided until the end. A lot of matches are won and lost every year. Some are lucky others are not. But, after the initial analysis of the matches is completed, the winners are usually granted the crown and deemed the better alliance in those matches, by the majority of people. I'm not sure we have been deemed that, yet. Or maybe I am just getting sensitive and cranky as I get older. |
