Go to Post Why assume a full trophy case and spreading the message of FIRST (mentoring rookies) are mutually exclusive? Team 16 supported 6 rookies this season and earned 5 banners - I am equally proud of both. - Meredith Novak [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 11-04-2014, 11:36
Deke's Avatar
Deke Deke is offline
no team (No Team)
Rookie Year: 2013
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Re: Out stretching surgical tubing.
Originally Posted by menns View Post
The curious thing we discovered about stretching surgical tubing is that the restoring force decrease by about 10% for about 40 seconds to a minute after it's stretched. We get the most catapulting force if we stretch it and release it immediately. We suspect this was throwing off our two ball autonomous.
I'm guessing this a thermal effect. Rubber produces heat when stretched. It then cools to room temperature but rubber expands when it cools so less restoring force.
Something doesn't quite add up here, are you sure it was the surgical tubing causing variation? If there is a power loss from the tubing, it should be a steady decline and not self restored. Maybe over time the tubing slides or rotates where it is mounted and changes its tension, just a thought.
Unread 11-04-2014, 13:12
shewejff shewejff is offline
Jeffrey S
AKA: Jeffrey S
FRC #1025 (Impi Robotics)
shewejff is on a distinguished road
This is what's called viscoelastic creep. It's common for elastomeric materials. That reduction in force will start to happen fairly rapidly when the elastomer is placed under load, but the final force will eventually level out (sometimes after hours under load). I used to perform analyses of EPDM rubber, and our EPDM rubbers would eventually level out at about 70-75% of the original load.
If you remove the load, the elastomeric material is none the worse for wear, and will load again exactly how it did the first time. For example, if I pull the surgical tubing to 100 lb and hold it at that distance for a long time, the force will eventually decay to 75 lb (for example). If I release the force and pull it back to that same distance, it will take the original 100 lb of force to do so, not the 75 lb that it was just at for that distance.
I haven't performed any tests on the surgical tubing to look at its viscoelastic creep behavior, but this might be a good experiment for a team to do.
