Go to Post I do know that I cringe every time someone brings up "lawyerism" or some other such nonsense as the reason their interpretation of the rules is right. - Kris Verdeyen [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 11-04-2014, 11:44
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Low Rider Club 2014
On this year's robot, we had roughly 1/16" ground clearance.
Our ground clearance started just below 1/8", where the bottom of our lexan bellypan was. There were originally pan head bolts and rivets below the bellypan, but as the robot wore in (ie: was pounded in) we began to completely ruin the whole field of tape at Dallas (2 times) as our tubing frame slightly shifted. We moved all of the bolts and busted out the Dremel to ground down some bolt "tails" so the lowest point of the robot was the bellypan itself, which had sunk down to 1/16".
After 2 regionals, we have huge scratch marks (like sandpaper) all along our plastic bellypan where we were still slightly sliding around.
Ground clearance is defined in this club as the height of your bellypan (or similar large, horizontal plate) off of the ground. How low are you?
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 11-04-2014, 12:12
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: Low Rider Club 2014
When we're on our omni-wheels our belly pan is just under a 1/4" from the ground. We have bolts and the 72 tooth gears that come close enough to the ground to collect any loose bits of carpet. We collected a lot of carpet this year. Our pretty white frame isn't so pretty on the inside anymore.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 11-04-2014, 12:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The bolt heads out the bottom of our frame are just a smidge over 0.25" from the ground. We didn't go lower because we didn't want any issues with running over loose nuts/bolts on the field.
GitHub
Unread 11-04-2014, 12:26
Canon reeves Canon reeves is offline
FRC #4490
Rookie Year: 2013
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
We have about 3/4 of an inch of clearances, at one point we ripped up a piece of loose tape and it cost us a bearing and a belt!
Unread 11-04-2014, 13:08
Chris is me's Avatar
AKA: Pinecone
At the lowest point, our bellypan is .4375 inches from the ground. The completely flat field let us switch to 4" wheels while still using the 3" drive tubes we are used to. We did not experience any scraping this year.
In the past we've had CIMs as close as 3/8-1/4" from the ground. These CIMs had scrapes on them as well as a collection of metal shavings presumably grabbed off the ground.
Unread 11-04-2014, 13:17
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
You sir have an amazing drive base if your belly pan can hold a half a thousands tolerance!!!!!!
Unread 11-04-2014, 13:21
AKA: Pinecone
It's probably more like .435 factoring in that the plate is probably .063" thick rather than exactly 1/16th. Also forgot to factor in powdercoat, which adds at least 2 thou.
Unread 11-04-2014, 13:24
RoboChair's Avatar
Now we just need the field and the field TAPE to live up to these numbers!
Unread 11-04-2014, 16:33
SkittlesCharge's Avatar
SkittlesCharge SkittlesCharge is offline
Alumnus Extraordinaire
AKA: Klager
FRC #0537 (Charger Robotics)
Rookie Year: 2012
SkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to all
537 had 1/2" inch ground clearance with our belly pan this year. In our videos from competitions, you can see our belly pan sticking out below the bumpers, but you can't (easily) see the wheels, so it kind of looks like our robot is hovering 1/2" off the ground.
Team 537 Website
At The Control - FRC Webcast Dashboard
Unread 11-04-2014, 16:34
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Geez, makes us feel positively sky high with ~3/4" clearance.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 11-04-2014, 17:06
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
Rookie Year: 2011
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Add us to the 1/16" low rider club...
Our cross braces and electronics mounting rails are welded under our frame, so everything sits nested inside the frame.
It only became a concern when we had a code issue in auto. Our first practice match of the season we ran into the wall in our torque gear and in those 10 seconds we burned through the carpet and toasted a brand new set of Vex 4" Versa wheels.
In fact, that practice match in teleop we were unable to move since in the time between auto and teleop the carpet and what was left of the tire material cooled and we were GLUED in place. The field techs were so happy with us!! Took a good 10 minutes to pry the robot from the field.
Of course the practice matches were held on the game field and every time we set up our robot throughout the event we could not help but smile. We were concerned that we would trip breakers with our 6 CIM drive. After the wall burnout we felt that was no longer an issue. Plus seeing your "patch" when you went to set up you robot, priceless....
Luckly we had a bunch of spares. This is our first time using a west coast drive and wasn't sure of how badly they could wear tires out during defense.
We have upgraded to Colsons for the championships.. Hope they wear better.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 11-04-2014, 20:05
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
Rookie Year: 2012
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
It would have been funny for you guys to play in our last qualification match at Dallas. Our mecanum wheels broke, and I bet a roller would have high-centered you guys
Unread 11-04-2014, 23:10
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Team Role: Mechanical
Rookie Year: 2010
Rynocorn is on a distinguished road
Our robots belly pan was on the ground in the center during most of our matches and the bolts holding it one he front and bag dragged along the ground. We called it an "traction device" and not a cad error. At one point, some tape had overlapped on the field wand the carpet was a tad pulled up and I got the robot stuck on it for a bit.
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
