Go to Post If you want to win, steal from the best, invent the rest. - Michael Corsetto [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 14-04-2014, 13:48
Chris is me's Avatar
AKA: Pinecone
Re: Amount of coupler purchase required on 1/2'' hex?
Originally Posted by Oblarg View Post
That's a cool idea, but it'd be harder to manufacture and I want to be able to swap the gearboxes easily as well as the wheels.
Wouldn't it be exactly the same? Two plates, a tube, some standoffs? You just unscrew the gearbox and lift it up to remove it.
  #17   Spotlight this post!
Unread 14-04-2014, 13:53
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Originally Posted by Chris is me View Post
This is a bit of a tangent, but looking at your specific design, maybe you could build a gearbox that straddles your rectangular tube? Instead of driving a live shaft, have a gear off the gearbox drive another gear bolted to the wheel. I feel like this might achieve what you're trying to do (shifting gearbox with CIMs over drive wheels) a bit better than the coupler solution.
This is a great idea and I think very similar to what 971 did in 2012, and I believe still do. If you go towards this method you might want to have a look at what they did. It's explained here http://www.chiefdelphi.com/forums/sh...ht=971+gearbox
  #18   Spotlight this post!
Unread 14-04-2014, 14:19
Oblarg Oblarg is online now
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Ah, crud, you're right; removal is actually easier with that design. No idea what I was thinking there.
However, currently the lower half of my shifter is exactly the assembly from the WCP 3-CIM dog shifter; designing it to sit on top of the tube would probably entail changing that, and being a lazy engineer, I want to do as little designing as I can get away with
Moreover, my wheels fit pretty tight right now, so doing that would probably actually lose me overall space, since the tube would have to move in far enough to allow me to put a gear on the other side of the wheel.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
  #19   Spotlight this post!
Unread 14-04-2014, 16:04
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
For a coupler, I'd probably take a 1/2" deep well socket (six point) and part it off in the lathe. I'd have no worry that the coupler would fail. As for the shafts, that's what summer testing is for...
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #20   Spotlight this post!
Unread 14-04-2014, 17:46
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
I don't think you need to put the hex coupling inside the tube. You could put it in the tube and in the wheel. The sdp si .375 hex sleeves have an id of .625, so you could use it as your drive axle if you want.
If you do something like this, you'll need to make sure that the holes/bearings in the frame as well as the output shaft of the gearbox are concentric, otherwise you'll never get it together.
  #21   Spotlight this post!
Unread 14-04-2014, 18:00
AKA: Eli Barnett
Yeah, this'll be the biggest issue. Thankfully, our team does know a machinist who can do these things to fine precision, so I'm not too worried about that.
  #22   Spotlight this post!
Unread 14-04-2014, 18:03
AKA: Pinecone
The tricky part is lining up the two separate parts perfectly. I would see if you could add some kind of feature to one that aligns it with another.
For example, on our gearboxes this year we counter-bored the hole for our flanged bearing so that part of the bearing would stick out the gearbox. This would snap into the hole in the frame and ensure concentricity.
Many ways to do this, it's just particularly important for this purpose.
