Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Go Back   Chief Delphi > Competition > District Events
Unread 14-04-2014, 13:51
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
MSC Team Ranking Changes pre to post MSC 2014
Dear CD,
FRC3548 finally dialed in our 10 point Auton Shooter for MSC and scored 9 out of 11 times. In the Howell district we used a 1 pt auton. Even with that significant improvement in robot performance our pre MSC to post MSC ranking did not change (rank 60ish/64).
So, I ran a quick ranking evaluation of all the teams attending MSC and simply looked at the delta change pre and post MSC. I found some teams that had significant decreases in ranking and others that had significant increases and I was wondering why these changes occurred. Did your robot break down during MSC (107 dropped 49 in rank, 2054 minus 29) ? Did your drivers have a lot of practice post districts on a practice bot? What do you attribute your significant change in state ranking (2834 - plus 39) (910 - plus 44)? Do you think you had an "easier" or "harder" match schedule?
Are you willing to share your "secret sauce" so 3548 and others can improve for next year?
Team # MSC Rank Delta Team # MSC Rank Delta
Post - Pre Post - Pre
107 -49 4003 24
2054 -29 245 25
5193 -29 1506 26
3602 -28 3641 33
2851 -28 1918 36
3175 -28 2834 39
4391 -27 910 44
815 -25
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 14-04-2014, 15:09
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Re: MSC Team Ranking Changes pre to post MSC 2014
There are many possible reasons. Here are a few that I can think of:
1) Robot issues at an event. If you have some issues at a district but get them fixed you could expect to climb. If your issues were at MSC, you can expect to fall.
2) Event strength. Teams that attend stacked districts are more likely to climb at MSC while teams that attend lesser districts are more likely to fall. Example: a team may do great at a district without much depth, but may only be the 10th best robot at a district like Waterford. That means the points that a team earns at a district depend on the depth of the district.
3) Luck of the draw. Schedules do have an impact.
4) Outside factors. Sometimes a great partner team's robot breaks during a match. If that happens in the rubber match in elims, that can create a big qualifying point swing. Likewise for scoring issues, penalties, etc. Or, a key match in qualifications can juggle the draft order which could cause a big change in how points are awarded.
5) Alliance needs. A great qualifying robot may not be what is needed by alliance captains causing them to slip down or out of the draft.
An ounce of perception is worth a pound of obscure.
Unread 14-04-2014, 15:17
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Team Role: Coach
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Marc,
I think most of the change in ranks came from the Alliance Selection Points.
There were teams that won events that didn't get selected or got picked up late in the draft. Most of this comes from Chris' statements about Alliance Needs.
-Clinton-
Unread 14-04-2014, 18:56
FoleyEngineer's Avatar
FoleyEngineer FoleyEngineer is offline
AKA: John Crombe
FRC #0910 (Foley Freeze)
Team Role: Coach
FoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond repute
For 910, I think it was 3 factors...
1) Robot improvements - Our first two events showed weaknesses in our winch and gatherer, and we didn't play "smart." We were semi-finalists in those two, but by the time we went to Buckeye, we had those fixed and got wins there and at Troy. We always look at what we can improve on and work like crazy between events to make ourselves better. We test it on our practice bot and implement it at the next competition.
2) Driver practice - Every event they got better. They found just the right balance between offense and defense. They're never sitting still. They also got better at playing while being heavily defended and also at shutting down opponents. They also learned to "tuck" the ball while driving to eliminate "pop outs" from hard hits by our opponents.
3) Strategy / Teamwork - Watching our own "game films" along with hundreds of online ones from around the country helped us determine how to play better, and as a unified team. Having a plan ahead of time to switch plays on the fly based on if we have an opponent shutdown for example helped us keep scoring while preventing the opponents from doing so. Flexibility and teamwork often helped our alliance beat a stronger one that might not be playing as "one mind".
We're just hoping that we get the kind of awesome cooperation / teamwork at CMP that we have in Michigan!
Cheers!
2014 Buckeye Champions - thanks 846 & 639, Troy Champions - thanks 33 & 5193, Imagery, Entrepreneurship & Industrial Design Awards
2013 Kettering Champions - thanks 70 & 862, Three Imagery Awards
2012 Western Mich Finalist - thanks 1918 & 85
2011 Trav. City Web Site, Troy Xerox, Mich State Semi Finalist & Judges Awards
2010 Kettering Champion - thanks 67 & 70, Kettering Rockwell Innovation 2010 Troy Finalists - thanks 33 & 288, and Rockwell Innovation
2009 Kettering QF, Detroit Finalists Detroit Creativity Award, Troy Semi-Finalists Troy Creativity Award
2008 WMRI Finalists - thanks 1243 and 904, 2008 Kettering Champion - thanks 67, 1075 and 2619
2008 IRI Judges Award Winner, Great Lakes Finalists - thanks 66 & 217, Western Mich
2007 Curie Division Champions - thanks 330 & 1270
Unread 15-04-2014, 14:50
stuart2054 stuart2054 is offline
Controls Mentor
AKA: Stuart Sebright
FRC #2054 (TECH Vikes)
Rookie Year: 2010
stuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nice
Cheers!
I thought you looked very good. Your dedication and hard work showed.
Congrats
2054 Tech Vikes
Unread 14-04-2014, 20:26
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Rookie Year: 2013
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Just something I wanted to point out - Our team only dropped 11 places, not 28.
And to answer your question, we had robot problems on Thursday with our auto not working, and once we got it working (sort of), our code overall stopped working, and we had electrical problems, a joystick die in one match (Q53) and also had a chain slip off one match (Q32). Whenever we were working, our alliance partners made us play defense, either because they did not trust us to get the job done, or they saw we had 6 CIMS on our drivetrain. There was two matches where we were allowed by our alliance partners to play offense. I honestly do not believe that our robot was the 64th best robot at MSC. Also, I believe that our schedule wasn't one of the easiest ones at the event. Missing CMP by 3 MSC wins kind of hurt, especially when we went 2-10
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 15-04-2014, 14:48
Controls Mentor
Rookie Year: 2010
Originally Posted by marccenter View Post
Dear CD,
107 -49 4003 24
2054 -29 245 25
5193 -29 1506 26
3602 -28 3641 33
2851 -28 1918 36
3175 -28 2834 39
4391 -27 910 44
815 -25
I would say it was a combination of things. We had a moderatly tough schedule that by OPR stats suggested we would be 6-6 as we ended. you can see that here http://www.chiefdelphi.com/forums/sh...pre+event+data
The field was deeper than in the districts we attended although West Michigan had many of the same teams there and was quite deep as well.
I thought we played well but did not often show how our catching ability could be usefull inbounding from a human player.
I think we were percieved as not fitting the desired position needed by the alliance captains. We didn't like it but that is how it goes sometimes.
2054 Tech Vikes
Unread 15-04-2014, 17:05
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
This is what I had heard a few times.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 15-04-2014, 18:24
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
This was the case for the #1 alliance. We had 2054 high on the list of teams available, but when it came down to the pick, our strategy called for more of an inbounder/defender than a scorer/trusser.
When we played with 2054 earlier in the day, they did not feel they could "pass" the ball effectively without rocking the robot. We were concerned with their ability to inbound effectively and ball security.
We felt better with 74 being the inbounder than adjusting our planned strategy to fit for 2054.
Unfortunately, sometimes alliance selection comes down to the perception of which robot style best fits an alliances planned strategy. Making the right second pick can make or break an alliance.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 16-04-2014, 12:25
Controls Mentor
Rookie Year: 2010
Talking Re: MSC Team Ranking Changes pre to post MSC 2014
I questioned why you picked 74 until I witnessed your strategy. They did a nice handoff to 1718 BOT to BOT which also kept the ball pretty secure. I believe we have an easier robot to pass into the when we go into catch mode and spread our "Wings" but we did not show that much. We also have a short range air cylinder "Puncher" that moves the ball back out to pass with but it would not be as seamless as the rotational movement of 74's pickup running in reverse passing robot to robot with 1718. We could have inbounded and passed over the truss to the human but then you still have to get both other alliance members the ball for the assist and is a break from the strategy you had.
Not to mention we did not show these other capabilities much during seeding. In fact I don't remember a case of us using our short pass cylinder that ejects the ball out our pickup mechanism side so who knew we had it or what it could do? I don't think we have fully explored strategies using it so you can't expect others to know about it.
I am least grateful to know as apposed to just assuming we were being considered and also the reason we were not perceived as the best choice. Knowing this should help us at the championship.
Thanks Adam!
2054 Tech Vikes
Unread 01-05-2014, 20:56
AndrewPospeshil's Avatar
AndrewPospeshil AndrewPospeshil is offline
meme lord supreme
FRC #0503 (Frog Force)
Team Role: Leadership
Rookie Year: 2011
AndrewPospeshil is a jewel in the roughAndrewPospeshil is a jewel in the roughAndrewPospeshil is a jewel in the rough
That's another thing that really skewed the alliance results at MSC this year; the game. Roles were incredibly important as opposed to just how good a robot was; seeding didn't matter as much as capabilities. This was also visible at Archimedes this year; the number 12 seeded team didn't even move on to elims (sorry, 639 :/). Any teams that didn't make it very far this year but still felt they had a good robot shouldn't feel bad. A lot of good robots just simply didn't bring anything new to an alliance so they weren't picked.
Chairman's Award Presenter // Vice President // Outreach Lead // Senior
2014: MIKET DCA // MILIV DEI // MICMP DCCA | 2015: MISTA DCA // MICMP DCCA
2016: MICEN DCA // MILSU DEI // MICMP DCCA
The opinions expressed in my posts are those of my entire community, team, and its sponsors. Everytime I make a post,
I have to gather everyone in one huge room and make sure I voice all of their thoughts in my post at once.
Unread 18-06-2014, 17:50
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Rookie Year: 2011
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
I'm interested in further analyzing this data for this past season in addition to previous years, however I am missing data for post week-6 rankings for 2010-2014. Does anyone happen to have these spreadsheets available or know who I can contact to get them?
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 18-06-2014, 18:23
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
As far as I'm aware, that data is not available in the format you're asking for it. However, you could tally the points for each team from the individual district sheets.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 18-06-2014, 18:33
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It's generally easier to subtract the championship points then add up district points.
  #15   Spotlight this post!
Unread 18-06-2014, 19:00
Basel A's Avatar
AKA: @BaselThe2nd
Sure. Either way it'd take a bit more work to reconstruct the tiebreakers, but certainly it's all public data. For the future, it would be nice to have a separate sheet in the workbook with the pre-MSC rankings.
-Paul Copioli
