Go to Post Welcome to FIRST. You've never seen anything like this. - Aignam [more]
Unread 18-04-2014, 17:42
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
RMS of OPR residuals at MSC
By request, attached is a chart that shows the RMS of the OPR residuals vector vs number of matches N played at MSC Quals.
A is the 256-by-64 binary design matrix of the alliances in Qual match schedule.
b is the 256-by-1 column vector of alliance scores for those Qual matches.
x is the 64-by-1 column vector of OPR values based on the first N matches in the Qual schedule. For MSC, N varies from 32 to 128. For N less than 32, the A matrix is singular.
For each of the 97 OPR vectors (for N=32 to 128), the RMS value of the vector of residuals Ax-b is calculated and plotted vs N.
Name:	RMS of Ax-b OPR residuals vs Matches at MSC.png
