Go to Post Woah woah, what about fingers? The programmers have to use something to type with? - dellagd [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 20-04-2014, 14:36
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Buying good 3D Printer?
We are looking for a good 3D printer to play with in the "off-season" so we could possibly see if using it in 2015 would be a possibility. We don't have an outrageous amount of money so please keep that in mind. I do want one that makes pretty strong parts considering what it is made out of. I know I say some teams using hubs and such made with them and they worked well. Any ideas guys?
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 20-04-2014, 14:39
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Buying good 3D Printer?
Why not a small lathe or mill (unless you already have one)?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 20-04-2014, 14:46
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
We already have a lathe/mill combo. We would love a CNC plasma or something similar but do not have the money for that.
Unread 20-04-2014, 14:53
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
Rookie Year: 2011
MrRiedemanJACC will become famous soon enough
Depends on what you mean by good....
I have a Dimension BST, which is very old, but I can say for sure that the Dimension is a solid machine. We made our corner pieces for our frame out of 3-D printed material and the axle mounts. We were successful with both. I don't have access to my work computer today with the models of our corner pieces or the axle mounts, but I can get them to you later if interested. They were both designed to be attached specifically to 20 mm 80/20 extrustion (they held up to a pushing match with you guys in the eliminations at Lansing until we tripped our main breaker - that's what we get for using 4 Cim's and 4 mini-Cim's on the drivetrain).
The new Dimension Machines run about $15,000 and they are said to have material that is 25% stronger. But that always depends on how you use it. Loading is everything! Edit: (oh yeah the $15,000 probably fits into the too expensive category) Edit end.
We also have two Makerbots. Be ready to tinker with the Makerbots, they are good machines, but there is downtime associated with them and expect it to be a good learning experience.
I have just placed an order from multiple vendors for about $1200 in total of parts and should be able to make a MendelMax v1.5 with that. I will be assembling one over the summer and next year in my class we will be assembling a second one. I'm sure there will be a learning curve to it, but if you can build one, we will know the in's and out's of 3-D printing and that is the goal I have for my students. It should look something like this when done: http://www.mendelmax.com/wp-content/...96fbaa5d9.jpeg
Also, check out Michigan Tech's website and the Square One Education Network. They have a program for teachers where they can go to Michigan Tech this summer and build a Delta Style 3-D printer. I believe they are booked. I was hoping to get a grant to put on another program such as that in Jackson, but I don't think the money is going to go through. For about $13,000 Square One Education Network will supply the parts and the expertise to set up another training and have 10 printers built in 3 days...
Here's the link to the Square One Education Network Professional Development http://www.squareonenetwork.org/prof...l-development/
Let me know if you have any other questions.... And good luck next week!
Unread 20-04-2014, 15:01
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
I was looking at the Makerbot replicator 2x...I don't have really any knowledge beside self research. I know for a fact we probably have 4,000 to work with.
Unread 20-04-2014, 15:12
Rookie Year: 2011
We have a Makerbot Replicator 2. The biggest problem I am seeing is that that "extruder" is too close to the nozzle and the material melts inside the "extruder". Then the print stops.
So here's a more detailed explanation. Basically you start with filament that is a solid, push it with an "extruder" and it goes through a heated nozzle that melts the material to "lay" it on the bed. The "extruder" is not a screw, it is a wheel that turns and pushes the filament to the nozzle. The extruder though is connected directly to the nozzle which has the heating element. Once the heat transfers to the extruder from the nozzle, the filament starts to melt in the extruder and then it is essentially pushing a liquid. Now I'm sure it can be fixed, but that's where we are with it and I'm letting my students adjust the temperature to find a good balance.
Most of the homemade solutions pull the extruder away from the heating element.....
Unread 20-04-2014, 15:24
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Would these problems be fixed on the new 5th gen version?
Unread 20-04-2014, 15:27
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
We have a Replicator 2, and have not experienced any problems like this. For us, the machine has been pretty much draw and print. We have tons of parts on our competition bot that were made by the printer - and honestly, it revolutionized our build this year.
In the interest of full disclosure, the machine is down right now waiting for parts from Makerbot. We took it with us to the DC Regional, and it would not operate when we arrived and set it up. Makerbot support has been fairly responsive, has sent one part along with installation instructions, and is currently sending a new motherboard.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 20-04-2014, 15:47
Rookie Year: 2011
I do have to agree on the responsiveness of Makerbot. They have been absolutely spectacular every time I've called. No questions asked, they ship what you need at no cost.
Unread 20-04-2014, 23:06
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
If you want an idea of what is available for the "hobby" market I suggest picking up a copy of the Ultimate Guide to 3D printing.
It's already a bit outdated since a new printer seems to pop up every other day. http://makezine.com/volume/guide-to-3d-printing-2014/
Also as already mentioned I would recommend one of the newest Makerbot machines. They seem to have the easiest to use machine and probably the best support.
There are other options, but it all comes down to cost and how much tinkering you actually want to do to get a useful print.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 21-04-2014, 17:16
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Rookie Year: 2007
Bald & Bearded is on a distinguished road
Second what badbrad said above.
Also, go check out the reviews and problems reported in the forums on reprap.org.
While the plug and play nature of Makerbots and some of the other off the shelf printers is attractive, for learning, experimenting and being able to modify things I like the RepRaps.
As someone above said the MendalMax is a solid DIY printer.
There are several very good Prusa I3 kits out there that are a bit cheaper.
To keep cost lowest go with a Prusa I2 kit.
A while back I posted a presentation I gave on 3D printing at a local FRC workshop. If you can't find the thread on CD PM me and I will send it to you direct.
The short story is:
1. Invest in a heated bed.
2. If you want to do stronger materials than ABS(e.g. nylon) invest in an all metal hotend. However, not all allmetal hotends are equal so read the reviews.
Unread 22-04-2014, 07:27
FIRSTgenius FIRSTgenius is offline
FRC #3318
FIRSTgenius is an unknown quantity at this point
I have to disagree. I have extensive experience with the MakerBot replicator 2 at Georgia Tech, as I managed the printer for the specific division. There was nothing but problems. We had to call them several times, and it was the worst support experience ever. I also now manage a Dimension 1200es SST. The printer is fantastic if you maintain it properly, but if you don't, you will have a lot of problems. I would recommend trying out the Form1 from Formlabs. I found the quality from the part compared to the makerbot and dimension was better, as it uses resins instead. The detail on the model is incredible, and there are less issues then with extrusion based printers.
Unread 22-04-2014, 09:01
Canon reeves Canon reeves is offline
FRC #4490
Rookie Year: 2013
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
I don't have a 3D printer, but from what I've read, try to stay away from any printers that require you to buy special cartridges because right now filament is fairly cheap depending on which kind you use, but cartridges basically allow the company to control what you pay because the printer you have won't work without their cartridges. here is a good website that has various printers and their costs, http://www.3ders.org/pricecompare/3dprinters/
Unread 22-04-2014, 09:13
AKA: Bradley Rigdon
Rookie Year: 2000
The Form1 looks like a nice machine and even has some FIRST Alumni behind it, but the output may not be suitable for some robot parts where strength is important.
The material seems to have a lower tensile and impact rating than ABS. It also has a much lower temperature range. I'm sure the machine can output many parts suitable for robot use, but I think it would have more limitations in the areas that you can use printed parts.
It definitely looks easy to use and should be pretty reliable with few moving parts. Also they seem to take months to aquire, but that may not be a problem.
As with all machines maintenance is key and FDM/FFM machines especially low end need lots of care.
Quality/resolution of printed parts isn't everything. High resolution prints are awesome, but high resolution doesn't equal better. Ronnie is looking mainly for part strength.
As previously suggested I recommend Ronnie picking up the MAKE guide so he can review several options.
I believe the new gen Makerbots will be much better machines, but that is to be seen since they are so new.
I think the biggest factors anyone needs to review to determine what best suits there needs prior to purchasing:
Printer build quality.
Software interface ease of use.
Material options, properties, cost
Build volume.
Print resolution/accuracy
Support
Typed while on my 15 hour drive to STL. (No I'm not driving.)
  #15   Spotlight this post!
Unread 22-04-2014, 15:32
RunawayEngineer RunawayEngineer is offline
Master Commander of All Things Tech
AKA: Ches
FRC #0801 (Horsepower)
Team Role: Tactician
RunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to behold
Does anyone have any experience with the Ultimaker?
It looks to me like a middle ground between the plug-and-play and the DIY. The ability to buy a kit or assembled unit, as well as the availability of modular addons, looks like it would be great for a variety of educational purposes.
