Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 22-04-2014, 22:37
achfire achfire is offline
achfire is an unknown quantity at this point
how to avoid getting the same data continuously
as you see when i enter the 2nd data it remplaces the 1st one ..if you can tell me what to do to see just data that i enter in the client,and the 2nd data in the 2nd row and so on.
thanks a lot
here is the blockdiagram of the client where i can see the result in a table
Unread 27-04-2014, 18:37
Re: how to avoid getting the same data continuously
I'm not certain I know exactly what you are going for, but the key concept is that the table itself doesn't append data. That means the diagram needs to append new data to the older data.
The typical approach is to use a shift register or feedback node to keep the table. Then you have an event or button to add the new row and update the table. It is also possible to use the table itself to store the data. I can't post code at the moment, but I'll try to do it a bit later.
Greg Mckaskle
Unread 27-04-2014, 19:11
thanks ,i'll try ur solution
