Go to Post Have you been formally diagnosed as a masochist, or are you just a mentor? - GeeTwo [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 01:16
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
=========STRATEGY PROBLEM #3==========
Posted by Anton Abaya at 02/22/2001 2:59 PM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
Robots A, B, C, and D.
A limbos, can balance 2 goals.
B picks up balls but needs the bridge. Arm can be used to lower bridge.
C limbos and has an arm for balls and can be used to push 1 goal on the bridge. Arm can be used to lower bridge.
D can also balance 2 goals but needs the bridge.
No ramp robots, so see-saw effect is eminent.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: =========STRATEGY PROBLEM #3==========
Posted by EddieMcD at 02/22/2001 11:34 PM EST
Student on team #121, Islanders, from Middletown High School and NUWC.
In Reply to: =========STRATEGY PROBLEM #3==========
Posted by Anton Abaya on 02/22/2001 2:59 PM EST:
Have D just go to the endzone. D takes the bridge first. B lowers the bridge, and goes over to the endzone.
C goes to the other side. A pushes the near goal to the Alliance Station, and goes to the other side. C puts a big ball on far goal, and hits the endzone. A grabs far goal, crosses the bridge, grabs near goal, and balances.
If done in under a minute, and saying that the human players get in 15 balls, that's a score of 550 for A, B, & D, and a score of 605 for C
#0047 (ChiefDelphi)
Posted by Chris Orimoto at 02/24/2001 3:33 AM EST
Student on team #368, Kika Mana, from McKinley High School and Nasa Ames/Hawaiian Electric/Weinberg Foundation.
Again...exact same strategy. This time, put D on the stretcher.
C goes straight for limbo to grab big ball while A grabs D on the stretcher. B pushes goal back to alliance station.
A pulls stretcher over bridge first. B pushes ramp down, goes over and hangs around by ramp. After all this time has passed, C should be ready to cross over bridge again w/big ball. C crosses over and B (being on the far side) pushes ramp back down to far side and then heads for a big ball. While C is dumping big ball into near goal, A should have dropped off the stretcher and hooked onto the far goal. (B had pushed the bridge to the far side) A then comes over the bridge back to the near side. During this transition, C should have deposited the big ball and headed for the limbo to endzone. A grabs the two goals and takes time to balance...enough time, in fact for B to grab a big ball and position it to be placed on the "far" goal after it is balanced.
This is a little different from the previous two scenarios, but it works. Being a little more complex, I think the 450 score is more likely here.
10+10+10+10+10+10+15=75
75*4=300
300*1.5=450
I do think though, that this is very accomplishable in 1:45.
Just my personal thoughts...
Chris, #368
[IMG] code is Off
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
