Go to Post I remember as a kid thinking how high a team number like 834 was. - Dancin103 [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 07-07-2014, 19:02
MatthewC529 MatthewC529 is offline
Lcom/mattc/halp;
AKA: Matthew
FRC #1554 (Oceanside Sailors)
Rookie Year: 2013
MatthewC529 is on a distinguished road
Re: Android Driver Station
Originally Posted by raystubbs View Post
I know this is an older post, but just so people know there is an app on the android market called ´aLogcat´ that does allow you to get log info.
Alternatives include CatLog, Logcat Extreme, Log Viewer and so on. Plenty of apps to this. Thanks for adding that on!
It wouldn't hurt to have a logging utility built in to the app though no? As an easily retrievable log file? A simple endeavor using Log4j. I have also been looking into the best way to retrieve a video feed, automatically changing and reverting the IP and keeping track of the Team Number between application instances. Just to make it more convenient without having to have people dig through the Network Settings to run it on their phone, it would simply be more convenient to have the app do it for you with sufficient permissions.
Team 1554 -- Oceanside Sailors
  • 2013-2014 - Lead/Sole Programmer
  • 2014-2015 - Lead Programmer, President
  • 2015-? - Team 1554 Mentor
Independent Public Projects
Developer at Legend Zero LLC.
Java/C++ Programmer
Last edited by MatthewC529 : 07-07-2014 at 19:06. Reason: Correction and Clarification
Unread 10-07-2014, 09:18
raystubbs's Avatar
raystubbs raystubbs is offline
Programmer, Builder, Designer
FRC #2657 (Thundercats)
Team Role: Student
Rookie Year: 2012
raystubbs will become famous soon enough
Yes, I've figured out all of this except efficient video. I just haven't taken the time to implement the features. This app was designed to be functional and light, but not super convinient. It was more a test run than anything. Right now I'm working on whan I want to be the final implementation of the app. One of the main complaints with the current one seems to be that it is not compatible with all drive systems. So on this other implementation I am going to add the other requested features, but also I'm adding a 'drag and drop' interface to customize the layout of the controls.
"If all else fails, read the instructions."
Unread 20-07-2014, 01:23
raystubbs's Avatar
Team Role: Student
Rookie Year: 2012
Published the app on google play to make it easier to download.
https://play.google.com/store/apps/d...erstation_lite
Unread 29-06-2014, 23:51
dmaciel10123 dmaciel10123 is offline
The Everything Guy
AKA: David Maciel
FRC #3525 (The Nuts and Bolts of Fury)
Rookie Year: 2013
dmaciel10123 is an unknown quantity at this point
Originally Posted by tanogirl View Post
This might be a stupid question... but is there a trick to installing it? I have an Asus MemoPad and could get it to install but the app wouldn't open.
Is it crashing or just not opening at all?
Unread 30-06-2014, 05:37
The Everything Guy
AKA: David Maciel
Rookie Year: 2013
Originally Posted by guniv View Post
It may have something to do with his Android version. That sounds like an old device that prooooobably isn't supported very well.
Now that Android Wear watches are out, someone should make this app for it
It could be the version or the IP. When I was trying to get the camera working the app wouldn't open if the IP had more than 2 numbers in a segment (ie 192.168.1.70) because of the way the all sets the team number from the IP. All depends on the way it's acting when they try to open it.
If they were able to install it though I don't think it's the android version.
Unread 30-06-2014, 07:04
tanogirl's Avatar
tanogirl tanogirl is offline
AKA: Emma
FRC #3038 (ICE)
Rookie Year: 2014
tanogirl is an unknown quantity at this point
Its not the device, its less than 6 months old and running Jelly Bean- could that be the problem? And this is what I get when I try to open it Click image for larger version
Unread 30-06-2014, 09:44
The Everything Guy
AKA: David Maciel
Rookie Year: 2013
Its not the device, its less than 6 months old and running Jelly Bean- could that be the problem? And this is what I get when I try to open it Attachment 17136.
Did you change the IP on your device before opening it? Go into the WiFi settings and long tap the network you're on. Tap on modify network and then check the "show advanced settings" option. Then change the IP Settings from "DHCP" to "Manual" or "Static", and change the IP to 10.12.34.6 and the subnet mask or gateway to 255.255.255.0
This may solve the crash but you'll lose Internet connectivity until you put the network back into DHCP mode.
To use it on a robot you'd change the 1234 in the IP to your team number, ie 10.35.25.6 for my team.
Unread 30-06-2014, 12:00
tanogirl's Avatar
AKA: Emma
FRC #3038 (ICE)
Rookie Year: 2014
Ohhh that was it! Got it open and it looks great! Can't wait to try it with one of our bots!
