Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 30-04-2014, 22:13
YCJeon772's Avatar
YCJeon772 YCJeon772 is offline
Mechanical Leader, CAD designer
AKA: Yuchan Jeon
FRC #0772 (SabreBytes)
Team Role: Mechanical
Rookie Year: 2012
YCJeon772 is an unknown quantity at this point
Custom Gearboxes
So our team has been thinking about designing custom gearboxes to achieve a fast high gear and strong low gear. How do teams create such fast/strong gearboxes? I tried playing around with the JVN calculator to see what I could get but couldn't get what we wanted.
2014 North Bay Regional Engineering Inspiration Award
2014 Windsor-Essex Great Lakes Regional Chairman's Winner
Unread 30-04-2014, 22:19
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Custom Gearboxes
I'm not really sure what you mean by "we couldn't get what we wanted" out of the JVN calculator. Were you using the single speed or two speed tabs? Were you using all the tooth counts of gears that are available from FIRST vendors?
My typical process for drive train gearboxes is to determine what my design parameters are for the gearbox (shifting or no? max speed/min speed? certain time to distance requirements?), then playing around with JVN until I get a set of gear ratios that work.
I guess the main thing about the JVN calulator is that, like all calculators, it's only as good as what you put into it. It's not magic-- one of the often ignored parts of design is determining what exactly you want out of what you're designing. In my experience there hasn't been a single gearbox I've designed that the design wasn't at least in part simplified by the JVN calculator.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 30-04-2014, 22:27
YCJeon772's Avatar
AKA: Yuchan Jeon
Rookie Year: 2012
When I said "we couldn't get what we wanted", I meant that we couldn't get a fast speed for high gear and a strong low gear. I was using the two speed tab, and yes, I was using the gears that Vex offered. We were hoping to get at least 13f/s for high gear, and a reduction of at least 10:1 gear ratio.
Unread 30-04-2014, 22:29
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
What's driving these numbers? How do you know you want a 10:1 gear ratio? Wouldn't that depend on the wheel size a little bit? And what you're doing?
Unread 30-04-2014, 22:30
YCJeon772's Avatar
AKA: Yuchan Jeon
Rookie Year: 2012
Well we just want a general gearbox that would have a fast high gear and a strong low gear, and we use 4 inch wheels.
Unread 30-04-2014, 22:37
FRC #0079
Rookie Year: 2000
So, why build your own? That sounds like a pretty cut and dry use of COTS components? For example http://www.wcproducts.net/wcp-shifter-3cim/ (scroll down to the charts for the speeds) has several options that meet your needs.
I'm not saying don't go custom, just saying that you might want to look at options and see what concepts you can steal.
Unread 30-04-2014, 22:43
YCJeon772's Avatar
AKA: Yuchan Jeon
Rookie Year: 2012
I think it would be nice to learn making custom gearboxes. If it doesn't work, we could always buy them. And I never knew that site that you gave me existed, so I didn't know if there was something like that.
Unread 30-04-2014, 22:46
AKA: Nick Aarestad
As they say, steal from the best, invent the rest. I'd agree that looking at COTS options and borrowing their ratios is probably the best option for you. You might also want to be a bit more flexible with your design-- if you're designing for a certain speed and ratio, you might need to be flexible with your wheel size, for example.
tumblr | twitter
VEXU UMN (2015-??)
Unread 01-05-2014, 10:07
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
You could even take it a step further and borrow the entire COTS design, and simply make whatever modifications to the plates and gear setups you deem necessary to get what you want out of it. There's no shame in copy-pasting stuff from a published CAD in FIRST
Originally Posted by PingPongPerson View Post
stoichiometry to get from CIM RPM [5000ish] to feet per second
I don't think that's the word you wanted...
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 01-05-2014, 14:42
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
Smile Re: Custom Gearboxes
You are not calculating reactant amounts, but the process is the same
Team 955
Raiderbot
Unread 01-05-2014, 22:52
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
In both situations, the process is called dimensional analysis.
Unread 01-05-2014, 23:35
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
We should probably calm down. Ask yourself: does it matter? Why am I arguing?
Generally, when doing actual speed calculations you should use a good calculator like the JVN one. I can't comment on it's accuracy, but at least it provides a general estimate of what to expect with the tread you are using.
Unread 02-05-2014, 00:37
AKA: Eli Barnett
Well, I hope you're not calculating your robot speed strictly by dimensional analysis, because on these scales a factor of, say, 2pi is important.
Unread 30-04-2014, 22:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Actually, I've alwasy been confused about something in the JVN calc: it lists the draw at maximum output load, but is that the normal drive load or pushing match load?
  #15   Spotlight this post!
Unread 30-04-2014, 22:38
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
WCP's drivetrain calculator gives a more in depth analysis than the JVN calculator. http://www.wcproducts.net/how-to-drivetrain/
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
