| Thread Tools |
Rating:
Display Modes |
4-speed gear automatic gearbox
I jokingly mentioned to a teammate earlier that we should cad a 4-speed gearbox, but now that I think about it, has anyone else ever done a 4-speed gearbox and controlled it like an automatic transmission in a car? It seems fairly straight forward, have an encoder on the shaft to determine if the robot is either stalling (trying to push another robot) or has stopped accelerating (has hit full speed), and in response, either shift up or shift down.
Has anyone done anything like this and do you think it is worth doing? |
Re: 4-speed gear automatic gearbox
FRC0033, Killer Bees, did one many moons ago. http://www.chiefdelphi.com/media/papers/1580
Bear in mind that the motors used are no longer FRC-legal. And yes, this was automatic. I seem to remember that associated code filters wound up in a sponsor's product because they were handy. |
Not sure if anyone has ever done it before, but from a practical standpoint, I can't imagine a situation that would justify the complexity and relative bulk of a 4-speed gearbox.
From a design standpoint it's relatively straightforwards. It would just be either the addition of an extra shifter stage (if you wanted to try to use COTS shafts/parts), or a custom shifting shaft and multiple-position cylinder/actuator. If you wanted all four speeds on the same shaft, you'd probably find it easiest to use a custom ballshifter. (Though I don't have any experience with >2 speed drives.) Last edited by wasayanwer97 : 02-05-2014 at 01:49. |
Was it ever built/used? Is there a video of it? |
Team 968 did a 4-speed gearbox a couple different years. I want to say it was 2004 and 2005. I don't remember if it was autoshifting though.
On 696, we tried an autoshifting algorithm on our 2-speed this year and did not find any appreciable distance in field-crossing time when compared to leaving it in high gear, even with varying the shift point through a range of set points. |
It's not extremely difficult to autoshift. Normally you would be in high gear, but the driver would have a low gear override pushbutton to go into low gear for normal driving. Then you could just put a current sensor in the motor circuit and shift into low gear whenever current gets too high. 4 speeds seems excessive to me, because all you really ever need is a normal drive gear and a low pushing/ positioning gear. You can also just use PWM control to lessen the duty cycle of the motors if current spikes. Last edited by asid61 : 02-05-2014 at 02:24. |
Side note: I believe that 217 did a CVT in 2002. That may be of interest. Last edited by Jeffy : 02-05-2014 at 14:29. |
Here is the main problem with anything more than a single or 2 speed gearbox:
Time The field is 54 feet long, and (this year) 25 feet wide. The furthest distance you could possibly need to travel, straight line, is ~60 feet. The question is not whether you get more top speed out of 4 gears, but whether or not you can do such a thing in 60 feet, including stopping. If you have a straight line top speed of 30fps (or 1116.437fps for that matter), if you cannot reach said speed by the time you cover the length of the court, you have an improperly designed gearbox. We ran a 5.5fps and a 15.5fps drivetrain this year, with 6 CIMS in ballshifters. The actual, tested, realistic acceleration time we got from starting in first gear, reaching 5.5fps, then shifting up "on-the-fly", only gained us hardly measurable time. We, like most if not all teams who use shifting gearboxes do not use them for decreased acceleration time, but for torque vs speed selection-low gear for plowing, high-gear at all other times. Integrating some smart code to decide which gear to use based on wheel speed is definitely a good thing, but not why the shifters were chosen for the design. Is such a challenge to build a compact 4speed transmission a great off-season project? sure- but consider this before using it on next years game: the field is everything. If you save 0.1 seconds crossing the field with your new system, but you only do it 2-3 times a match, is it worth all that effort just for the extra 0.3 seconds you gain? Also, if we have another game like 2010 or 2010, having more speeds is useless because the field is even smaller. Also, will you ever get a straight-line path? more often than not, no. There will be some field element, or one of the other 5 robots in you way, that you will have to steer around. Steering slows you down, in all cases of tank drive, as you must slow one side to turn that direction. That will further hinder your capability. Sorry for being the Debbie-Downer, but that is my $0.02 |
We used auto shifting this year, and it did help us get up to speed faster. I can't comment on the specific technical aspect as to why, but in both 2013 and 2014 our robot always starts in 1st then shifts up to 2nd on the fly then back down to 1st when we come to a stop. It puts less strain on the battery - we could leave it in second all the time while we had a fresh battery, but found it could quickly get run down.
#10
recommend less led lights on the robot next year 624, it might save some battery
#11
When I was on 195 as a student in '05 I copied the 33 design, made a few changes and we used it on our robot that year with our (at the time) perennial tank track drive. It was cool, fun, and a great experience BUT wholly unnecessary.
#12
Not that this is the thread for that, but the amount of LEDs they had on their robot...I don't even think they were drawing much more than an amp.
#13
Automotive automatic transmissions are used because of a narrow range of speed from the power source (engine) and a high range of output speeds. Electric drives typically don't use a shifting transmission because a motor produces torque from 0 RPM to a high RPM plus they can remove cost associated with a transmission and final drive. I could see a 4 speed more useful in FRC if used like an ag tractor trasnsmission where different speeds are used for different tasks. For example: speed 1 - power takeoff speed 2 - ultra-low pushing gear/high precision driving (4 fps) speed 3 - low gear for typical game play and acceleration (8 fps) speed 4 - high gear for quickly travelling 60 feet (16 fps) |
