Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 02-05-2014, 22:36
anomalynerd anomalynerd is offline
FRC #3250
anomalynerd is an unknown quantity at this point
pic: 4speed1
Unread 02-05-2014, 22:37
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: pic: 4speed1
Cool setup. Is that carbon fiber on the plates? What was the core material?
Was any kind of auto-shifting used? What kinds of speeds did this achieve?
And, why the huge teeth on the final stage gears?
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 02-05-2014, 23:07
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: pic: 4speed1
I would take a guess that they manufactured the final stage of gears themselves. Whatever method they used, that was the size of tooth they may have been able to make.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 02-05-2014, 23:26
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: pic: 4speed1
This is a very cool use of carbon fiber. It looks like it's foam core. What thickness is the carbon fiber plate? How did it handle having the bearings in it? Did you have to use inserts for the bolt to prevent crushing the carbon fiber?
It looks cool and you have me interested.
Unread 03-05-2014, 01:51
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Re: pic: 4speed1
Saw this team at either SVR or SAC and can confirm this. They mill their gears, using an 1/8" endmill IIRC, and say that they like how they can get gears a lot quicker than through SDP-SI.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 03-05-2014, 06:07
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: pic: 4speed1
How did you make the carbon fiber plates? Would it be possible to make a piece with a 90 flange?
Unread 03-05-2014, 14:33
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: pic: 4speed1
better talk to 2485 they are experts on making, molding and baking their own carbon fiber (and kevlar) parts.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 03-05-2014, 17:49
FRC #3250
Re: pic: 4speed1
The composite plates are carbon fiber, kevlar, and a foam core material with epoxy resin.
This was actually one of our first attempts with composite plates where we made a mold for the materials, where now we fabricate the composite plates and then machine them out after.
The gears have to have a 5.8 diametral pitch because we machine them on our cnc mills in shop. The drive system ends up with either 5:1, 10:1, 20:1, or 40:1 gear reduction.
Unread 04-05-2014, 00:06
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: 4speed1
WOW this looks pretty hardcore. It looks like the depth was kept down so you're not realy using space.
What was the motivation behind using 5.8 pitch gears over "normal" 20p, 16p, or 12p gears?
Unread 04-05-2014, 00:18
Redo91's Avatar
AKA: Justin
Re: pic: 4speed1
anomalynerd stated why they make them the way they do.
Emphasis mine.
That said, why not purchase a cutter that will cut the tooth profile of something with a larger DP? You seem to have a machine capable of using one.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Last edited by Redo91 : 04-05-2014 at 00:33. Reason: Italics don't emphasis in quotes...
Unread 04-05-2014, 02:03
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
Re: pic: 4speed1
Might not have an indexing head, or have more of a router setup than a mill setup.
-Plutarch
Unread 04-05-2014, 15:21
Rob Greene Rob Greene is offline
FRC #3250
Team Role: Coach
Rookie Year: 2010
Rob Greene is an unknown quantity at this point
Re: pic: 4speed1
Emphasis mine.
Our team does overbuild many parts. We used the Lewis gear formula and found that 5.8dp would work well with a high factor of safety. We did break multiple 20dp vex gears in this drive system. The gears are very big and we are looking to reduce to a 6.5dp on the next system we build. The other very important factor for these gears is 100% based on the tooling we have at the time of build.
Unread 04-05-2014, 15:24
FRC #3250
Team Role: Coach
Rookie Year: 2010
Re: pic: 4speed1
Yes, tooth size was based upon using a 1/8 endmill.
