Go to Post ...remember RAID 0 is a trap. - Sperkowsky [more]
Thread Tools Rating: Thread Rating: 78 votes, 5.00 average. Display Modes
Unread 04-05-2014, 16:00
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
VIAIR 250C-IG Compressor
We found this compressor that by the looks of it meets requirement of FRC rule book for 2014 season.
http://www.viaircorp.com/250C-IG.html
I wanted to hear your guys input especially if I missed something in the rules.
Because it looks like far superior compressor comparing to VIAIR 90C while still under FRC's 1.05 CFM limitation.
Unread 04-05-2014, 16:02
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: VIAIR 250C-IG Compressor
Yep it's legal (the 12v version), we used it and loved it! It is heavyyyy so we can it off board.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 04-05-2014, 17:23
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Thanks Mk.32 for quick reply. It's good to have a confirmation.
Before we found it, I started to work on a heat sink design for 90C cause it was getting very hot even with small fan. I probably better finish design, share it and may be someone would benefit from it.
Unread 04-05-2014, 17:36
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
It is a fantastic piece of hardware. Never even got too hot to touch. It's hefty, but if you need the air, it's worth it. We were asked by probably 10 teams about it and many seem very interested. If you can afford the weight costs, by all means get it. We won't be using the others ever again unless we are too close on weight or don't have many pneumatics. We were a little worried about current draw, but it's no worse than the 90c. Be aware that Q&A said that it is required to use the stainless steel braid leader line and you need to design for that since it is heavy and cumbersome.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 04-05-2014, 19:59
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Thanks, good to know.
Q&A you are referring to, is it Q325?
Unread 04-05-2014, 21:22
Rookie Year: 2011
Yes, that's the one, bit of a bummer since it weighs so much and is hard to deal with
Unread 04-05-2014, 21:52
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
I compiled comparison table of compressors I found meet the FRC requirements. I hope it may help someone
Unread 04-05-2014, 22:19
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
And here is heat sink design I was working on.
Unread 04-05-2014, 23:41
Nick1912's Avatar
Nick1912 Nick1912 is offline
If ya ain't first ya last
FRC #1912 (Team Combustion)
Team Role: Driver
Rookie Year: 2010
Nick1912 has a spectacular aura aboutNick1912 has a spectacular aura about
I believe his is another FIRST approved compressor which I was told 254 used this year and with 17 pistons it probably got a good workout (someone may want to check me on both of those). It is only a little heavier than the KOP compressor too http://www.gd-thomas.com/product.aspx?id=12622&tp=p
1912 Combustion Student 2011-2014
FLL student 2009-2010
FLL Mentor 2010-????
Unread 04-05-2014, 23:58
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
we used this to good use.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 05-05-2014, 00:28
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Oh yes, thank you.
I saw that one but was too lazy to add it to the list. It seemed not much better, yet quite a bit more money.
On the other hand it still viable option and will add to the list.
Unread 05-05-2014, 02:29
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Does anyone know how this compressor compares with the old KOP compressors as far as weight and fill rates?
Unread 05-05-2014, 08:45
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
Yes, see the comparison table I compiled
http://www.chiefdelphi.com/forums/at...6&d=1399254659
Unread 05-05-2014, 09:18
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
WildStang also used the new (Viair look alike) Thomas compressor. We liked it but it does not have a mounting flange or hardware. We considered that using any of the hardware on the compressor to mount it likely violated the "do not modify" rules so we made a custom bent aluminum tray for it. (Look for a change in the future.)
As pointed out, the Viair compressor comes with a stainless steel hose that is required by the manufacturer and so is required by the Q&A.
Al
WB9UVJ
www.wildstang.org
________________________
  #15   Spotlight this post!
Unread 05-05-2014, 09:25
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
This compressor? We used it this year. Great for weight savings and cfm is alright, but it really, really likes to heat up. We thought we'd give it a try after 254 used it last year.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
