Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
Unread 05-05-2014, 09:33
dmaciel10123 dmaciel10123 is offline
The Everything Guy
AKA: David Maciel
FRC #3525 (The Nuts and Bolts of Fury)
Rookie Year: 2013
dmaciel10123 is an unknown quantity at this point
Scenarios for Learning Java
Hi guys. I'm posting this thread to ask for some robot scenarios to program. I'm doing this because I'm experienced with Java but have not worked with it in FRC. My team primarily uses LabVIEW, but I would like to learn to work with Java and C++ as well. I may also use some of the scenarios you provide to help teach other programmers from my team who also wish to learn to work with these languages. I'll probably work with the 2013 version of the FRC libraries so I can use jRIO to test.
Edit: when I say scenarios I mean list different actuators, sensors, and functions that the robot would use.
