Thread Tools |
Rating:
Display Modes |
Re: "Electrical trumps mechanical"
Or is this history repeating itself?
Maybe I'm older then most of you, but I remember cars having a big silver (chrome) button on the dash to push when you wanted to run the starter. It was considered modern because it was better than getting out and turning the crank at the front of the engine. There was also a switch, later a key switch for security, to turn on/off the electrical system. The present-day ignition switch on the steering column came about as a mechanical interlock to prevent turning the steering wheel unless the key was inserted. It was a crude theft-prevention system that was easily defeated with a large screwdriver or dent-puller. All the electronics in cars now makes the mechanical aspect irrelevant. You can no longer rip a hunk of wires from under the dash and twist the ends together to steal a car, even if the movies say you can. You can't steer a car very well without the engine running either, so that interlock is irrelevant. And it would be trivial to interlock the transmission to the electrical system and make it impossible to drive without the systems permission. Keys with chips, or just a chip on a piece you keep in your pocket is all that is needed now. For that matter, they could use NFC or Bluetooth and let you authenticate your permission to drive with your smartphone. It already ties into everything else, why not? Stealing a car has gone from splicing wires to hacking. Keys may be nearing obsolescence, but they still give the owner a good feeling. They want to know their expensive car is locked down. And what do you use to get into the car when the battery dies? |
The push-button start and key start of modern cars both involve the same amount of electronics. If you turn a key on a new car for more than 20 seconds, the starter automatically stops. The same thing happens if you try to start a car that is already running.
The key on my car lets me turn on the radio, start my car, stop my car, and remove the steering wheel lock. On the steering column, there is a device that allows me to lock my steering wheel when I have the key out, unlock my steering wheel when the key is in, and shift out of park when the brake pedal is pushed and the key is turned. Just like the doors and locks in my car, the system has never failed. The system is simple, and works every time, even after 230,000+ miles of driving. Why fix what isn't broken? |
Many modern cars don't have steering wheel locks anymore, the thought being that since you can't hot wire it due to the transponder in the key the lock is not needed. On the other hand some cars have transponder bypass modes so you can start a car in instances where the transponder system has failed. They commonly require you to enter a code via actuating switches that don't seem related to starting the car. Here is the process for Honda built vehicles, I'm only posting this because the "code" is unique to the vehicle and normally only available to someone at an authorized dealer to look up. http://automotiveandcommerciallocksm...edure-for.html Then there is the case of snooping and capturing the transponder code, cars with push button start where you can leave your key in your pocket are most susceptible to this. Their transmitters are often motion activated so while you are walking along with the fob in your pocket you are sending out the code. The older transponder in the physical key is less likely to be able to have it's code snooped since it requires a very near magnetic pulse to cause it to transmit. |
After having both, the keyless start is a big pain because:
The 'stand next-to-the-door-to-unlock' doesn't work half the time. Gotta take the fob out. At that point, might as well have a slot to put it into and turn instead of a silly two-push button system that cycles through modes, when I could very clearly tell how far I had turned a key... and then awkwardly put the key fob somewhere not-buried so the car won't bing at me for not detecting a key. Big picture is important. If it doesn't add any value such as security, ease of use, reliablility, while increasing implementation complexity and cost, why do it? Only issue with mechanical keys is occasional jams. Might be me but we'd be better off developing a better lock. Or better yet, full keypad system? Punch in to lock/unlock, then once you're in it's yours. |
Point of data: Even the cars today with keyless start still have a key capable of unlocking the vehicle, and there's a sweet spot where a nearly-dead remote will still be recognized. In cases where there's no key lock on the door (say, the Cadillac ELR that uses touch pads), there is still a procedure to get a door open and start the vehicle. (Source (PDF), pages 2-7 and 2-12)
Electrical trumps mechanical like apples trump oranges.
In my limited experience in the sheltered world of an FRC team, I would make the argument that mechanical failures are generally easier to find while electrical fails are easier to fix. I know when a mechanical thing breaks, it usually takes lots of time to fix. Perhaps we go out to a match or 2 with it broken. I can fix most electrical problems in queue.
Perhaps that's because the electrical systems are designed by paid engineers, with more resources, and mechanical systems are designed under extreme time pressure by robotics teams, including high-school students. That being said: Quote:
1) The methods described in the video linked above were used to sink the Bismarck and destroy the Japanese carrier fleet at Midway, 2) The SR71 was developed by guys in crewcuts wielding slide rules and French curves, or 3) NASA got astronauts to and from the Moon using less computing power than today's toddler has in a LeapFrog. -------- Oh, yeah, electrical totally trumps mechanical. But it was not always that way. |
#10
In general, robots are interconnected, complex systems which rely on Software, Electrical, and Mechanical disciplines. None of these is any more or less important than any of the others. They ALL have to work in order for the robot to function properly. The best robot engineers, though they often specialize in one discipline, are familiar with and can troubleshoot problems with each of these disciplines. That said, for nearly every electrical problem I've come across (not all), in FRC robots, cars, power tools, household appliances, automated machinery, etc., can be traced back to a mechanical root cause. For example, people on the mechanical subteam love to blame wiring and connector issues on the electricals, and take a "not my job" attitude. But wires and connectors are just the mechanical devices whose job it is to get the electricity from one place to another. Similarly, I've seen electricals say they are just responsible from the wiring diagram, and think that physical implementation of the design is someone else's problem. Neither of these exclusionary attitudes is correct. It is everyone's job to be sure that the end result not only functions properly, but is reliable and serviceable. |
