Go to Post That settles it, no questions left. Water game. - Lil' Lavery [more]
Unread 08-05-2014, 08:07
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
What are the correct terms for linkages and lifts
In the past I've built robots that have an arm made of 4 pieces of metal that form a parallelogram. The right side is fixed, and as the arm is raised the left side moves up, but stays parallel to the right side.
I've used the term 4 bar lift for this, but have heard others write/say "4 bar linkage". While I agree it's a 4 bar linkage, it is a single case. 4 bar linkages can have each bar be a different length. With different lengths, the motion is quite different. Which term is correct, or is there a better term / phrase to use.
Moving on to 6 bar linkages. When I Google these, an entire universe of really cool motion possibilities is shown. I've built 6 bar lifts, where it's two parallelogram 4 bar lifts superimposed over each other (the left vertical bar is the right vertical bar of the next linkage, the upper bar becomes the lower bar in the next linkage).
Lets go back to 4 bar for a second. There is a set of lifts where the bars cross (make an X). You see these in "high lift platforms". I've heard these referred to as "4 bar lifts" or in some cases 8 bar lifts, since there are 4 bars on each side. But then I've heard that stacking them makes that an 8 bar lift. And more stacking is a 12 bar lift.
So I'm looking for a little terminology help here. I'd like to be using the right terms (that mentor thing) to be understood / understand what others are trying to tell me.
I'm good if we limit these to moving in the same plane. I was watching a video of a "4 bar linkage" where the points can move in 3 dimensions and that appears to open up a much bigger can of worms.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 08-05-2014, 08:22
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
Rookie Year: 2013
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: What are the correct terms for linkages and lifts
I always refer to it as a 4-6 bar linkage. Not all linkages are built to "lift" so I would stick with calling it a linkage.
The "X" lift you are talking about sounds like a scissor lift.
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 08-05-2014, 08:32
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
FRC #1675 (Ultimate Protection Squad)
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
When first refers to a "4-bar" or "4-bar linkage" they typically are referring to the system you described, where one side moves parallel with respected to the fixed side. Like you mentioned, this is only one particular case of a 4-bar linkage. The lengths and orientations of the bars and pivots can be adjusted to create a wide range of motion.
If you are interested, you can do some research on Kinematics (I took two full quarters of classes in college on this topic), and specifically 2 and 3-position synthesis. These are design problems where you specify 2 positions of motion and determine the lengths and mounting of the other links.
The "stacked 4-bars" you are referring to are known as scissor lifts. They seem like a simple concept, but can be very difficult to execute well. They require a high degree of precision as the links need to lie in the same planes as well as have the same lengths to prevent the lift from leaning.
Hopefully this answered some of your questions.
Unread 08-05-2014, 11:44
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
I'd like to point out that fore-bar linkages need not nessacarily have 4 bars.
Unread 08-05-2014, 12:35
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
Rookie Year: 2010
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
What is a fore-bar linkage? A quick google search turned up a bunch of results about four bar linkages (as well as this thread). I'm curious what you are talking about.
2015 Midwest Regional Finalists (Thanks to 2338 and 1756)
2014 Central Illinois Regional Finalists (Thanks to 4143 and 2039)
2013 Curie Division Semifinalists (Thanks to 2056 and 3990)
2013 North Star Regional Champions (Thanks to 2175 and 4607)
2011 10,000 Lakes Regional Champions (Thanks to 525 and 3642)
Unread 08-05-2014, 19:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The other term for a scissor lift, at least in FRC, is "What were you THINKING???" In addition to the degree of precision for the manufacture of individual links, they all have to go together precisely, and one end of the stack needs to be free to move horizontally, but not vertically. (This on top of the lift being rather unstable when fully extended--even a typical 26' lift can sway a bit when an average person walks from one end to the other while it's near the top of its travel.) Speaking as someone who uses one on a minimum of a weekly basis (and spent most of today on top of one), if someone successfully uses one in FRC, I will be quite surprised. (Current count of scissor-lift robots I've seen in elims: 1, maybe. On Einstein, 0.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-05-2014, 20:01
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Technically, 254's ball lift this year was a scissor lift... Just a very short single stage one.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 30-12-2014, 17:25
Joe_Chase Joe_Chase is offline
FTC #3397
Joe_Chase is an unknown quantity at this point
If we want to explore a linkage system quickly, we use a program called Linkage 2.0, developed by David Rector. Here is a link for a free download.
http://linkage.software.informer.com/2.0/
It is very easy to use and it is a fast way to explore a variety of systems. There are even examples that you can modify.
Unread 30-12-2014, 17:32
Abhishek R Abhishek R is offline
FRC #0624
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Does a scissor lift require the two parts to be connected in the center? IIRC, and please correct me if I'm wrong, but their pinniped was two separate mechanisms that acted individually or at the same time (so they could eject the ball out either end). If they were connected, they would never be able to remove the ball through their intakes.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 30-12-2014, 17:40
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
FRC #2175 (The Fighting Calculators)
Rookie Year: 2012
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
In 2013 842 used two small single stage scissor lift to raise frisbees into their shooter
https://www.youtube.com/watch?v=4nHd_bG5dZE
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 30-12-2014, 17:41
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Correct. The claptrap was two separate arms essentially, pneumatically toggled independently. No scissor.
Unread 30-12-2014, 19:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I have heard of the four-bar linkage with equal-length opposing edges referred to as a "parallelogram linkage", though I don't recall that I've ever read it.
