Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Unread 13-05-2014, 19:13
Briansmithtown's Avatar
Briansmithtown Briansmithtown is offline
Pilot shortage, Good thing Im tall
AKA: Brian Sheridan
FRC #0810 (Smithtown Mechanical Bulls)
Briansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond repute
Speed controllers going out of sync randomly
We need help asap for a very important presentation, and our robot is acting funky. It drives randomly. We asked Mark McLoed, and took his advice and it worked for a while, but it is acting up again. Please help
2014 Team 810 Recap video https://www.youtube.com/watch?v=DS9K_j1FzF4
Unread 13-05-2014, 19:18
NWChen's Avatar
NWChen NWChen is offline
Alum
Rookie Year: 2012
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Speed controllers going out of sync randomly
What was Mark's advice? Can you describe the issue in more detail (LED status indicators on speed controllers, what do you mean by "funky"/"randomly," have you made any code changes)?
2012 - 2015 • Team 2601
Unread 14-05-2014, 13:52
Petzer Petzer is online now
AKA: Peter Tarsoly
FRC #0810 (The Mechanical Bulls)
Rookie Year: 2010
Petzer is an unknown quantity at this point
Although I can't speak for exactly what Mark said as I wasn't present, as we turn on our robot from the breaker our Victor 888 speed controllers randomly give power to any motor controlled with a Victor 888. I do believe he said that it could be one speed controller causing the whole problem, but we haven't had time to test it yet. While disabled (meaning teleop and autonomous were not running), the LEDs mainly were completely off for the short spurts the motors moved. While in teleop, this behavior seemed to occur a bit more frequently except the other indication colors on the LEDs appeared. Again, this occurred without any code telling it to do so, as we once removed a PWM wire from one and the motor still continued as such. As Brian implied, the robot was acting normally before a couple days ago when it started acting like this.
Hope this helps, if you need more info please feel free to contact me.
Unread 14-05-2014, 14:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would start by removing all PWM's to the Victors - does the problem still happen with all motors? Or does that limit it to just some? If it limits the problem, replace the affected victor(s) and give it another try.
If it still happens with all the victors... try looking for a short somewhere. Check the power going into the victor and make sure you see appropriate +12V - it's possible you have a short that's feeding in reverse polarity (maybe attached to a motor, so it only shorts when the motor is in a specific position), which would cause funky issues and probably wreck the victors.
Try pulling the breakers to all but 1 motor controller - can you get that controller to behave properly? If so, add breakers back one at a time until things go funky - that'll tell you which power pathway/victor/motor is causing the issue.
If unplugging the PWM's fixes the problem for all victors, I would replace the digital side car and try again. It's possible there's some metal shavings in there that are giving an intermittent contact on the PWM control wires, or one of the chips may have gone bad/burned out to cause funky behavior.
When dealing with odd situations like this that appear to be system-wide, it's usually best to break the system down to its simplest form and then start adding features/parts back on - that way you can start from a position you know is working and find the area that is actually causing the problem.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 14-05-2014, 15:39
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Rookie Year: 2010
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I had a similar problem and found two problems.
One was a shorted motor and the other was the pins on a PWM cable that were shorting inside the Victor from being pressed in to hard.
Unread 14-05-2014, 16:14
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Consider swapping the digital sidecar. Random PWM signals is a failure mode of that part.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 15-05-2014, 23:05
AKA: Peter Tarsoly
Rookie Year: 2010
After looking over the digital sidecar quickly today, we discovered that it was the culprit. When we have the time, we'll be swapping it out with a good one. Thanks for the input!
