Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Unread 14-05-2014, 20:05
JoshD99 JoshD99 is offline
FRC #4327
JoshD99 is an unknown quantity at this point
Need help with west coast drive.
We are building a West Coast Drive chassis for our t-shirt robot. We have never done this before, but we think we know what we're doing. The only problem is that the gearboxes we're using, if we mount them directly to the wheel, will drag on the floor, as we are using 4 inch wheels. What can we do to fix this? Here are the gearboxes we're using http://www.vexrobotics.com/vexpro/ge...reduction.html
Thanks!
Unread 14-05-2014, 20:09
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Re: Need help with west coast drive.
Thanks!
I love to hear that teams are doing some work in the off-season.
From just the information you've given me, I'd say either use bigger wheels or a different gearbox. However, if you could send some pictures and/or CAD drawings of what you're trying to do, we could help you out much more.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 14-05-2014, 20:10
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
Not much. If you increase wheel size, you'll have to deal with higher top speed, which might not be desirable in a T-shirt cannon. Consider using 2-stage gearboxes.
Unread 14-05-2014, 20:13
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
Team Role: Coach
Rookie Year: 2011
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Can you specify which reduction you're using?
I don't have access to CAD atm, but I think the only one that would present that issue is the 12:84 version.
The only remedy I can think of, if you're absolutely sold on using THAT gearbox, is to use larger wheels, a different reduction, or to not direct drive (though it wouldn't really be a WCD anymore...)
Otherwise, using a different gearbox is probably the best way to get around this.
As far as 1 speed transmissions go, the AndyMark 3 CIM Toughbox might be a good replacement, as would this year's KOP gearboxes. (3 CIM drive is probably a bit much for a t-shirt shooter anyways...) Just note that you'll probably want the long hex output shaft.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
Rookie Year: 2011
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
West coast drives have a very specific type of gearbox, which has the gearbox's output shaft directly connected to the center wheel (if it is a 6wd). It also has chain/belt running through the center of the gearbox (usually).
We built a west coast drive this year using the WCProducts 3CIM single speed WCD gearbox variants. Notice how the output shaft is to the bottom of the gearbox and there is enough room to place a 4in wheel on the output shaft and not have the gearbox touch the ground?
Picture of said gearbox
Link to said gearbox
If you are set on using that specific gearbox there are ways to get around the gearbox touching the ground by chaining the output shaft to the center wheels, but then the drive would no longer be strictly speaking a West Coast Drive. Or you can always use bigger wheels.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 14-05-2014, 20:15
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Thanks!
As you discovered, you're not going to be able to direct-drive off of that gearbox with 4'' wheels.
Your options are pretty straightforward - you can either use bigger wheels, mount the gearbox elsewhere and link it with belt or chain, or you can use a different gearbox. The COTS options that will work with 4'' wheels, as far as I know, are all two- or three-stage.
If you have the machining capabilities and really want a singe-stage reduction and direct-drive center wheel, you can make your own gearboxes. Be aware that the ratios you can get with a single-stage reduction and 4'' wheels might not be high enough for comfort in an extended pushing match with a heavy robot and high-traction wheels, so if you're looking to have pushing power you might want to go with a different gearbox anyway.
Edit: Upon re-reading, I noticed that this is a t-shirt robot, so pushing performance probably isn't too important. Still, the advice stands if you want to transfer this design to an actual competition robot.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 15-05-2014, 10:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Here's a goofy out-of-the-box suggestion: use the small wheels to drive larger pneumatic tires mounted directly below them. That'll give you ground clearance without changing the gear reduction. The larger tires will also work better on non-flat surfaces, in case you want to use the t-shirt robot outside (perhaps during a football game).
Unread 17-05-2014, 01:30
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I think that would still cause a reduction like gears, due to the radius difference.
To OP:
Just use a two-stage gearbox. It's not that much more expensive to buy a two-stage gearbox than to buy a one-stage.
Alternatively, you can make your own gearboxes. It isn't frightfully hard to do given a mill/ xy drill press or CNC or sponsor for cheap. Designing gearboxes is fun too. You just mix and match vex gears to suit your needs.
Unread 17-05-2014, 01:34
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
Rookie Year: 2012
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
Is there a reason you're using single stage gearboxes? I would suggest, if your budget allows for it and if you're willing, to use either two stage gearboxes or 6 inch wheels.
Unread 17-05-2014, 02:05
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
A T-shirt robot can be used alot of places that require big wheels. I know that you want experience with WCD, but if you want to cross a football field, use big wheels.
Unread 17-05-2014, 03:52
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
FRC #0973 (Greybots)
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Thanks!
From experience, I would advise against using that specific gearbox. One of the internal bearings slides out quite easily and can cause the drive shaft to fail on the snap ring groove. If you haven't already purchased it, switch to another VEX gearbox like the WCP 3-CIM single stage, or the Vex Pro 3 CIM Ballshifter. Otherwise your options are to get bigger wheels (good idea for a t-shirt cannon anyways IMO), or to raise the gearbox and drive all the wheels with chain or belts. While this removes direct drive capability inherent to WCD, the other aspects of a WCD will remain the same without a dramatic change (with the exception of COG, which will be higher )
As mentioned before, machining your own gearboxes is also possible. My team ran a single stage 3-CIM gearbox geared for 16 FPS in a direct drive setup. They were very over-built, but rock solid throughout the season.
https://www.youtube.com/watch?v=feS_KxnsZ8s
(2015-?): 973
(2012-2015): 955
Unread 19-05-2014, 15:35
FRC #4327
Smile Re: Need help with west coast drive.
We decided to just use bigger wheels, 6 inch rather that 4 inch. Thanks for all the suggestions!
Unread 20-05-2014, 21:04
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Keep in mind that by increasing yor wheel diameter 50% like that, you will need to increase the secondary gear diameter 50% as well to keep the same speed. So your gear would still be scraping the ground. Plug the numbers into the JVN design calculator and you'll see what I mean.
Unread 20-05-2014, 21:22
FRC #4327
Well we actually realized we had some old smaller gearboxes (Tough box Minis) laying around that we're going to use instead and still stick with the 4" wheels. But thanks for the help!
  #15   Spotlight this post!
Unread 20-05-2014, 21:26
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Rookie Year: 2010
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
We used this gearbox this year (7:1) and it was our best drivetrain ever! Best speed and torque. That being said, I would suggest changing the gearbox! To much power and 3 CIMs is too much for a demo bot.
If you DO decide to use these i would suggest supporting the other side of the axle. On Saturday at CT State Champs we broke the axle clean in half (after 3 competitions, and many demos)
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
