Go to Post Remember the volunteering is not mandatory for the people to do it. It IS mandatory if FIRST is to survive and the regionals to leave a positive impact on everybody. - Alavinus [more]
Unread 14-05-2014, 20:40
lamk lamk is offline
Ken Lam
FRC #4719
Rookie Year: 2014
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Need help in deciding the configuration for an off season chassis prototype
We used the long configuration AM14u for aerial assist. It got us to St. Louis. As an off season activity I would like to prototype a 3 cim 2 speed 6 wheel west coast drive. I am leaning towards a 28 x 28 square configuration. My student wants to stick with the 23x32 long configuration. Any suggestions.
Unread 14-05-2014, 20:48
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Need help in deciding the configuration for an off season chassis prototype
How possible is doing both?
Generally speaking, WCDs are run long configuration. Sometimes someone will try a wide configuration. Not too many try a square.
It's the offseason. If you can't decide based on some other parameters, play a couple games of rock-paper-scissors-lizard-Spock to pick one, and put the other one on the list for next offseason.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-05-2014, 22:31
Ken Lam
FRC #4719
Rookie Year: 2014
There is a few reason why I am leaning towards a square 6 wheel WCD. Our driver has experience driving a long configuration for a whole season so I want them to drive something different to see how this configuration handle. I don't know it it matters: all the Einstein drivetrain this year were square drive including the poofs.
Once we have some experience building this chassis I don't think it'll be difficult for us to build a long configuration.
I'll be using the vex versachassis and 3 cim two speed ball shifter gear box.
I do like the suggestion of building a chassis that has the same dimension as our competition bot and put this year superstructure on it.
Unread 14-05-2014, 22:54
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
Rookie Year: 2011
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
I feel that has less to do with a square drive being "better" then a long drive and more of due to perimeter constraints, it was hard to acquire a ball being long. Thus many teams were forced to be much more square.
That said, there are a few things that I forgot to mention in my first post, that being long allows you to be taller without having to worry about tipping over as much as being square (or wide and having a shorter wheel base). But being square (or wide and having a shorter wheel base) usually enables you to turn easier with less scrubbing of the wheels.
I am not sure how much different it is to drive a square vs. long robot, but I doubt it would be significantly different. Maybe someone can chime in about that?
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 16-05-2014, 03:18
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
WCD generally has nothing to do with wide, long, square, or even the amount of wheels or type of wheels. It comes in all shapes and sizes, just like any other drive style. This style seems to be defined by the cantilevered wheels, which makes it easy to service.
Our drivetrain (WCD) this season would of been square, if not for the balls being so wide. Our base ended up being 28x27, wide. (We need just that extra inch for our intake to work ) With a six wheel drop center, the thing handled like a dream.
For an example of a square 4 wheel WCD, see 2590's 2013 robot Athena
Its all about the effective wheelbase compared to the track. When building a skid style drivetrain where unlike cars or bikes the front wheels wont pivot to turn, too small of a wheelbase will result in uncontrollable turning (turning to well). Too big of a wheelbase, and you'll have trouble turning. Its simply a ratio.
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 16-05-2014, 08:07
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
4967 Decided to cut the KitBot chassis into a 27.5inx27.5in square. This gave us a lot of frame rigidity. I can post pictures if interested.
L.A.S.E.R - Light Amplification by the Stimulated Emission of Radiation
Unread 16-05-2014, 17:20
Ken Lam
FRC #4719
Rookie Year: 2014
Please do!! My original plan was to exactly do that for the off season chassis but decided to try WCD because I feel WCD is likely more easier to configure and maintain.
Unread 16-05-2014, 17:39
Bryan1625's Avatar
Bryan1625 Bryan1625 is offline
FRC #1625 (Winnovation)
Team Role: Driver
Rookie Year: 2012
Bryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really nice
Team 1625 was a 27x28 bot (wide). I absolutely loved the drive this year too. It ran very smooth with a quick turn radius
Unread 16-05-2014, 18:32
AKA: Brandon Liatys
Rookie Year: 2007
4wd? 6wd? 8?
Frame dimensions generally don't decide how smooth your bot turns or doesn't turn, it's all about the wheelbase/track width. A 4 wheel drive of X by Y size will have more trouble turning then a base of the same size with a six wheel drop center.
Unread 16-05-2014, 18:56
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
We ran the kitbot wheel setup in a 29x26.5 configuration this year, and it turned like a champ. Probably worth noting that it was also very well-balanced; CM was maybe an inch or two forward of the geometric center of the robot.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 16-05-2014, 19:08
Bryan1625's Avatar
Team Role: Driver
Rookie Year: 2012
Originally Posted by Brandon_L View Post
4wd? 6wd? 8?
Its a 4 Wheel drive with 6 CIMs
Unread 16-05-2014, 19:24
Abhishek R Abhishek R is offline
FRC #0624
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Though I don't think it applies to this thread as much because your turning radius will be largely improved by having 2 omnis and 2 traction wheels.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 16-05-2014, 22:19
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Just a reminder, off the subject of dimensions, make sure you test the base under full weight. If your team generally build way under the weight limit and is 30lbs underweight, make sure you account for that. If your team pushes the limit to 119.9 lbs like we usually do, then your base when being tested should be around 140 lbs total (robot, battery, bumper). If you don;t test with weight you will see dramatically different traction results
If you want to get fancy you should even raise the weight a bit to account for how high your Center of Mass will be. Accurate testing in the offseason yields predictable results in the onseason.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 17-05-2014, 04:28
AKA: Brandon Liatys
Rookie Year: 2007
While that is true, there is also the major downside of being spun around in every collision that teams usually try to avoid.
  #15   Spotlight this post!
Unread 17-05-2014, 11:53
A Sentient Being
I'm having some issues uploading the photographs from my phone due to the weird format it saves them in. I will have them converted/uploaded later this evening. Sorry about the wait.
