Go to Post A robot is replaced every season by the next robot, but a friend, team member, mentor, and memories will never be replaced. - Jverdon [more]
Thread Tools Rating: Thread Rating: 12 votes, 4.92 average. Display Modes
Unread 05-24-2014, 03:01 PM
Mr. B.'s Avatar
Mr. B. Mr. B. is offline
Lead Project Manager/Mentor
AKA: David Bodmer
FRC #0011 (MORT)
Rookie Year: 2007
Mr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond reputeMr. B. has a reputation beyond repute
FTC - Tetrix kit vs. Matrix kit?
Question to all FTC teams/mentors...I will be adding the FTC program this coming fall to our FIRST program offerings and wanted to get input from FTC teams as to which FTC kit they would recommend Textrix or Matrix we purchase? I've been reading the kit descriptions but figured that asking those who have used these kits would be the best path to go! I would appreciate your input and thoughts on this topic!
Thanks,
Mr. B.
Unread 05-24-2014, 06:57 PM
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Re: FTC - Tetrix kit vs. Matrix kit?
I don't think you'll find many people who've used both.
We (My team, plus the four others run through BadgerBOTS) use Tetrix, and it's... alright. It has a lot of flaws, but I don't know if the Matrix kit is any better; I've never used it.
Tetrix has the advantage of being far more popular (at least in the USA), and so you'll have a much easier time getting help from other teams, borrowing spare parts, etc.
Honestly though, we try to stay away from the kit, because while it's nice for quickly slapping things together, Tetrix rails and parts are much more expensive than custom-made pieces, and generally weaker. But that strategy is dependent on you having access to at least a basic machine shop (Which pretty much every FRC team does already). For instance, here's part of our drivetrain from this year. There's some tetrix parts up above (Frame, motors, sprockets, standoffs, axles), but the majority of the structure is either custom machined (There are some custom axles and spacers inside there that you can't see too), or off-the-shelf (Andymark wheels, sprockets and bearings, 80/20, etc).
Overall, I find the Tetrix kit to be pretty frustrating, but that could be due to the fact that I'm much more used to making and designing things from scratch. And again, for all I know, the Matrix system might be just as frustrating.
Those little Tetrix D-shafts are pretty much junk for a lot of applications, you can't really transmit force through them, because the set screws will just dig in and the hubs will spin on the shaft.
Tetrix motors are also notoriously prone to burning out if you stall them for more than a second or two. And if you attached an encoder to that motor, you're out of luck, because the encoder can't be removed without damage. Again, I don't really know if Matrix is better in this regard.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 05-24-2014, 07:23 PM
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
Rookie Year: 2007
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
I've used some of the earlier Tetrix stuff (back in 2010 and 2011), and Matrix stuff more recently (this past season). The Matrix kit material is much lighter then the Tetrix, the electronics are wimpier, and a lot of the hardware is just not worth the price. Definitely go with the Tetrix.
However, with the more lax, FRC-style FTC rules nowadays, we're looking to do most of the body/frame work with custom materials (probably 1x1 box) and just using Tetrix electronics.
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 05-24-2014, 07:32 PM
Andrew Lobos Andrew Lobos is offline
FTC4977/FRC225 Alum
FRC #0225 (TechFire)
Rookie Year: 2011
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
The new Tetrix v2 motors have a lot of improvement in this area. We have not burned out any v2 motors this year. We had one instance where a gear in the integrated gearbox shattered, but overall they have been good to us.
At our local kickoff, the presentation from Tetrix spec'd the v2 at being able to be stalled for "over 2 minutes" without smoking.
I have had success with removing the encoder disc from the shaft by gripping the sides with a needle nose pliers and pulling it off. Then I used the tools from the encoder kit to put it on a different motor.
Unread 05-25-2014, 12:13 AM
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Rookie Year: 2013
Jalerre is on a distinguished road
As being one of few teams who has used both kits I must say I like Tetrix far more than Matrix. We used Matrix this past season and it was a terrible experience. The plastic gears slipped a lot, the screws stripped easily, and the parts are very filmsy. That's not even mentioning that we burned through all the servos provided in the kit. You apply even a little pressure to them while the robot is on and there done for. My favorite build kit personally is Vex but of the two Tetrix is the way to go.
Unread 05-25-2014, 01:29 AM
JTN's Avatar
JTN JTN is offline
AKA: John Taylor Novak
FRC #0016 (Bomb Squad)
JTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond repute
I hope this explains why my team uses Matrix over Tetrix.
http://youtu.be/lDmdjNbFbQg
They say I can't use a URL or BB code, so I'll use this for my signature.
Unread 05-25-2014, 01:36 AM
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
As an FRC Coach that is ready to start one (possibly two) FTC teams in the Middle School ranks - I am a bit concerned after reading these posts.
I thought that by going with one or the other kits (Tetrix vs. Matrix) either would be a great building block.
Now I am concerned about spending that type of money on either if they both have severe disadvantages.
Where do I go from here? I do not want to strap my future coach(es) with sub-par equipment.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 05-25-2014, 10:26 AM
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
Rookie Year: 2011
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
What specifically are you concerned about? Is it more so the electronics/motors or the structural hardware?
Unread 05-25-2014, 11:35 AM
Mr. B.'s Avatar
AKA: David Bodmer
FRC #0011 (MORT)
Rookie Year: 2007
Thanks for everyone's input! JTN will you be out at IRI in July? Would love to speak with you in person if possible. Let me know! Looking forward to seeing more posts on this topic! Much thanks!
Unread 05-25-2014, 11:58 AM
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I would suggest going with Tetrix. I have experience with both Matrix and Tetrix, by far Tetrix has been the easiest one to work with. I haven't run into any issues this year with what they provide for parts. With Matrix I have run into many frustrations. The electronics do not work well at all, I am still unable to get my Matrix control box to communicate with the NXT (in LabView).
Buy Tetrix kits, they work super well, they're easy to learn and they come with a ton of resources. Just remember to order your kits ASAP.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-25-2014, 02:23 PM
JTN's Avatar
JTN JTN is offline
Yes, I will be. I'm sure we'll see each other because our pits should be close together. The Matrix motors are a bit weak and the set screws could be a bit sturdier, but proper dimpling on the shafts and locktite in the right places makes the Matrix kit reign supreme. The push pins make prototyping so easy and the parts fit together in a much more fluid manner than do Tetrix parts. I can post some pictures if requested, but I'm too lazy to resize them all until then.
Unread 06-19-2014, 04:13 PM
Colton Mehlhoff Colton Mehlhoff is offline
no team (HiTechnic)
Colton Mehlhoff is an unknown quantity at this point
Red face Re: FTC - Tetrix kit vs. Matrix kit?
I would love to see some pictures if it isn't too much of a hassle John.
I'm new to the Matrix kit. If you could modify it in a way, what would you modify?
Unread 05-25-2014, 03:15 PM
CENTURION's Avatar
Working around the inadequacies of the system is a challenge, one that I think it's good for the students to deal with. Either way, you're going to have to use one of them at least for your electronics.
The Tetrix system isn't terrible, it just has a few shortcomings here and there, which provide a good opportunity for the students to learn about which systems work, and which don't. As I showed with the drivetrain earlier, it's possible to find a happy balance between Tetrix and custom parts. There are actually some kind of cool things built into the system, like how the motor output shafts are eccentric, it provides a built-in chain-tensioning system.
Unread 06-03-2014, 04:20 PM
gblake's Avatar
gblake gblake is online now
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Don't forget the 3rd option: VRC using the Vex equipment. If VRC's strong Middle School presence, VRC's year-round calendar/season, the timing and location of VRC tournaments in your area, the tech support infrastructure available, VEX equipment's pricing/reliability, VEX integration into Project Lead The Way classroom curricula, and the VRC program's worldwide reach match your needs; then by all means have it on your list of possible programs and equipment for your students.
Because each VRC season begins the day after the prior VRC world championship (mid-April), middle school students (who often *need* it) typically can enjoy a nice long build season before the North American tournament season is in full-swing, and they can study southern hemisphere teams' progress to get field-tested construction and strategy ideas.
The BEST program and equipment might be another option.
FTC/VRC/BEST/etc. all give students fun and inspiring experiences and challenges. Be a wise consumer and review them all to see which one matches your students' needs.
GBlake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
  #15   Spotlight this post!
Unread 05-25-2014, 06:06 PM
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Thanks,
Mr. B.
Back in my day. We didn't have all these choices.
It was Tetrix or nothing.
Tetrix has it's flaws. However, having messed with Matrix a little bit this past season. I think I'll be sticking with Tetrix until I see a need for some small matrix components. The V2 motors are the best revision yet. Even I haven't burnt one out yet. (I was very good at killing V1 motors.)
I'll counter with this is why 3864 uses Tetrix.
http://www.youtube.com/watch?v=z94A1GlU8Xk
Our robot is the one that the Y-NOT bot's team is face towards most of the match. It's pretty cool to me that it seems that 92 and 3864 came to very similar conclusions on the best way to score blocks. It was sad that we never played together in San Antonio.
Finally a throw back to my first season as captain of GForce. (Now Global Force). We had some pretty stellar rookie results. (World Championship Winning Alliance). http://www.youtube.com/watch?v=F59FXI30jzw
I'll be at IRI as well. Volunteering more than likely.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
