Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
Thread Tools Rating: Thread Rating: 12 votes, 4.92 average. Display Modes
Unread 27-05-2014, 09:41
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: FTC - Tetrix kit vs. Matrix kit?
The rookie FTC team I worked with this past year decided on Matrix. I believe they were the only matrix team at three or maybe even four of the events they attended (two qualifiers, MN State, and Super Regional)
We were not impressed by the Matrix plastic gears and wimpier axles, so ended up getting some parts machined by a local company that allowed us to interface some Matrix motors to Tetrix gears and then AndyMark 4" wheels. It ended up working fairly well (as you can guess by the events we attended)
The plastic push pin rivets do allow for quick prototyping of structures and can be very handy.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 27-05-2014, 20:52
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Whenever students or other teams ask me for FRC as to using a certain component (usually mecanum drive) I always say to them "look at what you have seen on Einstein"
The same applies to FTC and looking at DaVinci. I dont even think a matrix team got picked at the world championship.
But more so, tetrix has been around for almost a decade now, Matrix only a few years. So there are lots of resources out there when pertaining to using tetrix parts for your bot. Whenever I have held the matrix components they seem to be very...value engineered.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 27-05-2014, 22:47
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
If my team ever gets close to einstein I will make it my life's work that a set of mecanum wheels makes it on to the robot as ballast.
As for the debate here, we don't really use much of the either kit but we use tetrix because we already have the very large inventory. I don't think we will switch unless we have too. I think that as each year passes, less and less will be restricted.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 28-05-2014, 09:59
Git 'em!
Rookie Year: 2000
Yeah Technically there were mecanums there this year in the gripper of 2590 but not in the drive base.
Robot in 3 Days
Unread 30-05-2014, 18:02
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Our FTC team 3507 has used only Tetrix kits for 5 seasons now, but with the relaxed material rules of the last 2 years, we are phasing out use of very much of the Tetrix channel in favor of 20mm slotted framing with 10-32 assembly H/W.
As noted, the Tetrix axles are horribly weak and ill suited to high torque with bidirectional rotation. We will not use them for anything but low torque transfer purposes. The hollow 5/8" tube end fitting scheme, though improved with new parts is still not great either.
Tetrix channel is good for quick prototyping. There are also useful tricks, that allow overcoming some of its weaknesses. Some are shown in PICs below:
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 06-10-2014, 02:47
Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Rookie Year: 2013
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
Don't forget 1625's pickup.
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 05-10-2014, 20:42
robotsrule robotsrule is offline
robotsrule is an unknown quantity at this point
Robogamers made a video reviewing the Tetrix Kit of Parts as well as building both the tetrix ranger bot and the matrix bot. You can see the two side by side. Here are the links:
Robogamers tetrix kit:
https://www.youtube.com/watch?v=EDSCy-9WVfA
Tetrix Ranger bot:
https://www.youtube.com/watch?v=jnt3EVZaCxQ
Matrix Quick Start bot
https://www.youtube.com/watch?v=Hy4cswZ_Iqk
Some of the other videos may help out your new team members as well.
Hope it helps.
