Go to Post They didn’t have to help me. But they did. I have gained so much respect for all the mentors in FIRST from that point on. - Arefin Bari [more]
Unread 25-05-2014, 03:13
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Gear Center to Center question (and discrepancy)
Hello.
I was looking at designing a custom gearbox and came across the WCP center to center distance calculator. After playing with a couple values, I wanted to check if they were accurate. I downloaded the cad model for the VexPro 2 CIM ball shifter and discovered a problem; the distances calculated by the WCP calculator were significantly larger than those on the shifter. Namely, the distance between 40-44 gears should be 2.1020 inches. The shifter, upon inspection in solidworks, shows only a distance of 1.9882 inches center to center.
Could someone please explain this discrepancy? I fear that it may be me simply not using one of the two tools incorrectly, so I'd love if someone could clear up the issue.
Thanks,
Hades
http://www.wcproducts.net/how-to-gears/
http://www.vexrobotics.com/ball-shifter.html
Unread 25-05-2014, 03:20
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Re: Gear Center to Center question (and discrepancy)
Originally Posted by TheHolyHades1 View Post
Hello.
Thanks,
Hades
Could you be measuring point to point or shortest distance instead of center to center in SW? Sometimes SW decides to switch the measuring tool to closest or point to point measurements randomly, when what us FRC folk want 99% of the time is center to center (for holes, etc).
The nominal value for the 40-44 20 DP gearset is 2.1000". Whether or not you add in the .002" adder depends where you're using the gears in your design, and the quality of the gears.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 25-05-2014, 04:17
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I heard 0.001" is fine for clearance, but it really depends on who's machining it and how good you tolerance it.
The formula I use for gearboxes is (T1 + T2)/(P*2),
where T1 is the first gear teeth, T2 is the second gear teeth, and P is the pitch (usually 20 for FRC). Then I add 0.002" because I manual mill gearbox plates. Next year we're sending them out though.
Make sure that your cim mounting is really good. I add 0.002" for the cim gear to the first gear, because the cim does not press fit into the plate like a bearing. Rather, it is a very close fit with about 0.002" of clearance (diameter).
Unread 25-05-2014, 04:58
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Totally agree with Roger, Solidworks sometimes gets funky on the measure tool. But just verified real quick:
http://puu.sh/90hqe/ecce375103.jpg
and
http://content.vexrobotics.com/vexpr...g-20130104.pdf
Let me know if you have any other questions
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 25-05-2014, 14:41
Rookie Year: 2010
Thanks everyone for the speedy replies. I must have just been doing something wrong with SolidWorks then.
Now that I know that the WCP calculator is correct (not that there should've been much doubt, I suppose), I've created this spreadsheet with values for the center to center distances with various gears sold by WCP/VexPro: http://www.chiefdelphi.com/media/papers/3036
Thanks again!
