Go to Post Nothing says poor quality like a wrinkle in duct tape. - Matt C [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 02-07-2014, 21:38
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Re: Weight Saving Techniques
Originally Posted by Andrew Schreiber View Post
No... it's still required. Playing out here is rough. (This is partially joking, it's a lot rougher than I remember MI being though)
It was a rough game this year.
Unread 03-07-2014, 09:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
True but its a rough year every year up here even with bumpers.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 03-07-2014, 12:49
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Rookie Year: 2013
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Originally Posted by Kevin Leonard View Post
A lot of people on this thread have mentioned using thin-walled aluminum as a great weight savings technique.
A lot of people on this thread have not competed at a New England event.
I'm going to start by attesting to the New England defense, our robot took a BEATING this year.
195 always goes overkill on material thickness, but its almost always for good reason. Our intake this year was made of welded 3/16" aluminum. Overkill? Maybe... but did it hold up? Yes.
Here's some general tips (Yeah, they're probably repeats, but they can't be over stated.):
-Over account for electronics weight...wiring does have weight, and its more than you'd think. (IIRC we left 20-30 lbs for electronics this year.)
-Go a size above what you think will work for Aluminum thickness. Its better to be safe than sorry.
-Always do CAD estimates, but know that the estimate is lighter than what it will actually be. CAD is just mean like that.
As for weigh-ins... I suppose we got lucky last year in Hartford.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 03-07-2014, 14:43
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
CAD isn't mean. It's a computer program. GIGO. Your calculation is only as good as the information you put in.
Just for general information, material nominal dimensions are sometimes given at what is known as "minimum material conditions" (unless specifically noted otherwise with a tolerance). This means that the 0.125" sheet you buy might actually be 0.127". The 1"x1"x0.0625" square tubing usually has pretty good dimensionality on the 1"x1", but the 0.0625" is very much a minimum requirement. Strength calculations for structural tubing are based on the nominal size, so the piece has to be at least that strong. Suppliers will target thicker materials to make sure that with manufacturing tolerances, they meet/exceed the minimum. They, of course, have an incentive to minimize the excess material to save on cost, but there is always the extra bit. Extrusions also don't have sharp intersections on internal corners. The fillet of material will add to the weight.
CAD models can account for this if you model all features and include the maximum material conditions.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 30-06-2014, 17:02
abhem abhem is offline
FRC #0599
abhem is an unknown quantity at this point
Im sure the obvious technique is to always use aluminum as opposed to steel whenever possible. Swiss cheesing is also a great choice. To save on weight, our team uses gusset plates to secure vertical and horizontal posts rather than using crossbars. Although crossbars are very handy to secure posts, gussets work equally well, if not better when made correctly. They also save a ton of weight and lots of physical space on the robot.
Using gussets to secure "swiss-cheesed" bars/c-channel/etc. is a powerful combo to save weight
