Thread Tools |
Rating:
Display Modes |
Turning down the OD of a gear
I'm designing a gearbox that would work really nicely if a gear with an OD of 1.700 had an OD that was .020 less. How bad would it be to to turn down the OD of the gear .020? Also, does anybody know exactly the OD of a CIM motor? The website claims 2.54 max, but do they come in under this?
Re: Turning down the OD of a gear
I am not sure about turning down a gear. The CIM motors are 2.52 max, they vary depending on manufacturing within a couple hundredths.
If you turn down a gear .020"...
... Your chance of the gear slipping will go up, albeit slightly. ... Your chance of messing up the tooth profile will go up--you really don't want to mess that up, so make sure you clean up carefully after whatever machining op you do. ... If the gear is heat treated, you're probably going to change the heat treating. This will probably lead to unintended consequences, good and bad (but most likely mostly bad). But, you should be able to get away with it. For a little while, at any rate. Now, I have to wonder... Why not just move the gear .020" farther away from the other gear, in some direction? And, what's with asking if the CIM comes in under its stated diameter? If you're building a really tight gearbox, I suggest that you also CAD in the assembly tools for that gearbox, just to make sure they will actually work... |
The idea was to have three CIMs drive a large center gear, then have a smaller gear located underneath the CIMs, driven by this center shaft. |
Ah, I see. Maybe move each CIM .010" out from the center, and move the other smaller gear .010" down? Or is there some other space constraint that would prevent that?
That would mess up the center to center distances. |
That is true. On the other hand, part of design is designing for what is available. If the only available gear is .020 larger than needed, then that needs to be considered. Center-to-center shouldn't affect it--matter of fact, I'm specifically suggesting changing the center-to-center BECAUSE the center-to-center is too small for that gear, and the only thing a center-to-center will affect is where on the gear contact is made (though, that little detail can introduce some backlash, among other things). That can also be mitigated by playing with a few other things--for example, if your center-center is exact distance, most FRC folks will add 2-3 thou to that to account for manufacturing tolerances; if you make it 10 thou instead, you've really only added 7-8 to what is normally done.
Personally, I wouldn't attempt turning down a gear once it was cut, for the reasons listed above--there's too many things that could go wrong, minor enough it would seem, but just too many items to tempt Murphy and his gremlins. That goes for both a mill and a lathe, BTW. If someone really knew what they were doing, then that could work, but in FRC, those types of folks are rarer then we'd like to think, unfortunately. |
I do see the problems with the actually trimming the OD, depending on the team's machining expertise and capabilities it could be quite difficult to do. correctly |
Also, it's a lot easier to add 2-3 thou than 0.5 thou, something about the latter being much harder to do reliably, and needing better measuring tools. (Back in my day, a lot fewer teams had CNC capability. Then again, there were a lot fewer teams.) I'd go into a discussion of tolerancing and its effects, but that would be pretty far off topic, so if you're interested drop me a PM. Short version, X.000 vs X.0005 is probably going to be more expensive and time-consuming one way than the other. Take a wild guess which way is higher cost. |
#10
So yeah, I think we're going to .001 next year. I've heard people run zero backlash with Vex gears with no problems, but I'd like a little bit more space for grease in there, and this avoids having to break in gearboxes for any extended period of time. (The kids made me promise I wouldn't push for a geared arm again too) |
#12
My experience is similar to Eric's: the addition of up to 0.003 in was necessitated by gearboxes being produced by hand by inexperienced machinists on milling machines of uncertain provenance. If you're CNCing the gearbox plates, you can in all likelihood get away with less. But remember that the added centre distance isn't just for position of the holes, it's also for runout of the gear and perpendicularity of the axle. (For example, in 2006, 188 had a bad EDM job that screwed up some expensive hardened gears, and necessitated a lot of rubbing compound to "solve" the runout.)
I would be interested in hearing from some of the VexPro people about the design and tolerances of their gears. How far from standard tooth profiles can they be expected to deviate at perfect form (e.g. due to profile shifting, radiusing, etc.), and how much variance is introduced in manufacturing? |
#13
Turning the OD of a gear can have some negative issues as people have stated you are removing 10% of the active tooth depth. Depending on the tooth counts used this can have a much more dramatic effect than a 10% reduction in torque capacity. One of the factors that drive the rating of a spur gear is known as the contact ratio. It is essentially a measure of what percentage of time one tooth is in contact verses two teeth in contact. When you truncate the OD of one gear you shift that contact ratio closer towards one tooth in contact more often than two teeth. You could imagine when the load is shared between multiple teeth more more load can be transmitted.
Additionally many times gears have what is known as tip relief. Where the involute is modified slightly on the tips of gears to allow them to enter and exit mesh more smoothly especially when a load is applied. I do not know if FRC gears have tip relief machined in, but if they do you will remove it and possibly cause the gears wear more quickly and be noisy. How many teeth are on the CIM pinion? Would it be possible to use a larger pinion? If you are trying to keep a specific ratio vexpro might make just what you need. They appear to have some CIM pinions with modified addendums or shifted centers. (The modified addendums will allow you to add .025" of center distance without the increase in backlash or shaving the OD of your gears basically lets you set the center distance up as if the gear arrangement had an extra tooth). See page 9. http://content.vexrobotics.com/vexpr...ence_Guide.pdf |
#14
This is very case-dependent. Just remember that the teeth are designed to be in contact at the pitch-circle diameter, not at the outside diameter. So cutting the outside will have no effect on many systems.
So as long as you have 'regular' gears, not some kind of ten-tooth pinion or something, the outside two percent of the tooth should never be needed as the next tooth is engaged long before it disengages. Also, technically, involute teeth aren't sliding, they're 100% rolling contact, but if you change the center-to-center distance, even by adding a measley 3 thousandths, you'll have some sliding contact and less gear efficiency, more wear. But as someone above mentioned, what is the gear pitch?--if the teeth are very small, 0.020 could be alot. if they're big teeth, 0.020 is less concern. |
#15
Quoted for truth: It may not be obvious unless you have studied gears, but the teeth if an involute gear don't just push on each other, they actually ROLL across each other. The sliding action (which leads to wear and wants a lubricant) is almost zero. That's one of the reasons center-to-center distances are so very important for gearboxes.
