Go to Post I hate mini-bots. - Gdeaver [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 31-05-2014, 12:55
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Turning down the OD of a gear
And if anyone reading this thread hasn't had a chance to study a little bit about how gears work... take a look. We generally tend to look at gears and say, "Oh, it's just a gear." and take them for granted, but the math and science that goes into gear design is truly fascinating. The modern gear is the product of centuries of engineering evolution.
I know I've still got a lot to learn about how gears work, wear and are manufactured.
Jason
Unread 31-05-2014, 15:46
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rookie Year: 2012
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
Originally Posted by hrench View Post
Just remember that the teeth are designed to be in contact at the pitch-circle diameter, not at the outside diameter.
Isn't that a simplification of what the contact actually looks like. Gears contact along the line of action, which is some angle (the pressure angle) off the line tangent to both pitch diameters.
So as long as you have 'regular' gears, the outside two percent of the tooth should never be needed as the next tooth is engaged long before it disengages.
Wont removing that outside bit increase the stress per tooth?
Unread 01-06-2014, 17:48
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
Rookie Year: 2010
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
Absolutely.
Involute gears do not simply contact at the pitch diameter the contact moves from the tip to the root along the line of action as can be seen on the previous graphic. Gears all have sliding contact and most have at least one place on the line of action that has pure rolling contact. A gear mesh has three distinct actions during mesh. When a tooth begins in contact it is called the approach action there is a combination of sliding an rolling on the mating surfaces. When the contact along the line of action passes through the pitch diameter there is an instant of pure rolling. Then the contact goes into recess action where there is a combination of sliding and rolling once again. A shift in center distance will not change the fact that the contact will move from the tip to the root along the line of action it will simply make the line of action shorter and change the amount of backlash.
Unread 29-05-2014, 22:42
FRC #0192 (GRT)
Rookie Year: 2012
Originally Posted by T^2 View Post
I think this practice is also becoming slightly less common because of the prevalence of VEXPro gears. Their hex is oversize, while the shafts are undersize; this leads to slop. Adding .003 to c-c can lead to very noticeable backlash.
We did notice that too, but since we machine our own hex, we make it oversize to mate their bores nicely and haven't had those issues.
Unread 29-05-2014, 22:53
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Is it really that common in FRC to add 2-3 thou? (I honestly don't know) For every gearbox I've designed I've only added half a thou and haven't had any problems with wear.
Can you really hit a half thou accuracy? Even running finish and float passes and really getting to know the machine, program, and material, I can usually only hit around 1-2 thou accuracy on our CNC for stuff like hole to hole distances.
Yeah, 3 thou is the standard number. I've heard that it mostly came into being in a time when FRC gears were pretty low quality, VP gears nowadays are high enough quality that you don't really need the adder. Another reason for the adder is that if you have a bit of runout on your shafts, or poor quality gear teeth, and you put the gears at the nominal pitch diameter, there'll be places in the rotation where the gears get sort of jammed together, and you lose efficiency. Adding a few thou helps make sure that the gears aren't getting jammed into each other in case of tolerance issues somewhere else.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 29-05-2014, 22:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Quick question to the OP:
Why does this matter so much? If it's for clearance to spacers, just move the spacers. And if it's for ground clearance, forget it. You will need more ground clearance than 0.02" due to the tread wear, compression, and random stuff on the ground.
CIMs are always 2.536" outer diameter unfortunately. You could look into RS-775, but if this is for drive CIMs would work better.
Unread 29-05-2014, 22:24
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Originally Posted by magnets View Post
I'm designing a gearbox that would work really nicely if a gear with an OD of 1.700 had an OD that was .020 less. How bad would it be to to turn down the OD of the gear .020? Also, does anybody know exactly the OD of a CIM motor? The website claims 2.54 max, but do they come in under this?
By the way, what are the dimensions and diametral pitch of this gear? It's kind of important to know how much of the tooth is being lost. But maybe that's part of the solution: you could go with the largest teeth that will work. In most cases, the limit will be set by the undercut of teeth on the pinion as you go down to small diameters. (To improve that, prefer a higher pressure angle given gears of a certain diameter and the same pitch.)
