Go to Post We don't require innovation; we simply encourage it. - Tristan Lall [more]
Unread 03-06-2014, 00:00
Mr Roboto Mr Roboto is offline
FRC #3160
Mr Roboto is an unknown quantity at this point
Generating PWM signal
I want to control a window motor with a JAG motor controller using a joystick made up of micro switches. the reason for the JAG is to allow me to reduce the motor speed and utilize the limit switch function of the JAG. i'm not sure what i need to generate the signal, reduce the motor speed (potentiometer?) and reverse direction. is this even possible using micro switches? the unit is a pan & tilt for the top of a truck.
Unread 03-06-2014, 01:48
Mr V's Avatar
Mr V Mr V is online now
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Re: Generating PWM signal
The quick and easy way to do it would to use servos and a servo tester. That eliminates the need for the limit switches and a motor controller.
This one from AndyMark can also be used to control a motor controller. http://www.andymark.com/product-p/am-2503.htm Of course you won't be able to use a joystick with it whether you are using servos or motors. The plus side is that it has dedicated buttons to cause it to re-center or sweep through the range.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 04-06-2014, 20:00
DonRotolo's Avatar
Back to humble
FRC #0832
I posted a schematic for a servo tester you can build, definiteky in a thread and maybe also as a whitepaper. Several years ago. Go search.
It uses cheap and readily available parts and is easy to build.
